knightrider Posted December 11, 2008 Share Posted December 11, 2008 I lost a wheel due to my own error. I never checked the nuts after I initially put my aluminum wheels on. So long story short, I have a boogered up front hub that needs new studs. What am I gonna need to do this? I might just take the 3 12pt bolts out of the back and just put on a new hub...... Any tips, tricks or hints? Thanks fellas. :yes: Link to comment Share on other sites More sharing options...
BLHTAZ Posted December 11, 2008 Share Posted December 11, 2008 I was able to find replacement studs through an aftermarket supplier/store called Bumper to Bumper. They are Dorman part# 610-364. Anyone that carries Dorman stuff should be able to get them for you. You can always replace the hub assembly, but that is going to be expensive just to replace studs if you don't need new bearings. Link to comment Share on other sites More sharing options...
bigd44889 Posted December 11, 2008 Share Posted December 11, 2008 :agree: go studs if u can thay just press out or beat out with bfh hub run 70 for jap hub good for 1 wheeling trip or 170 or so for the good ones Link to comment Share on other sites More sharing options...
mvusse Posted December 12, 2008 Share Posted December 12, 2008 I had to replace a stud I broke at Badlands torquing down the lug nuts. Got a good laugh out of my buddy when I went flying backwards. But anyways, a new stud at Advance cost me I think $1.71. Three hits with a regular claw hammer (16 oz?) knocked the old one out, and I used a lug nut to pull the new one in. No need to remove the hub. I still removed the hub afterwards, though, to take the dust shield off. I kept getting gravel stuck behind it up against the rotor. Link to comment Share on other sites More sharing options...
knightrider Posted December 12, 2008 Author Share Posted December 12, 2008 I hit up advance auto tonite. Got them for 1.29 and I'm gonna tackle it Sat. Should be fun. I am also gonna do my front brake hoses. Link to comment Share on other sites More sharing options...
Impact Posted December 12, 2008 Share Posted December 12, 2008 just make sure you torque the nut on first before you put the wheel on to make sure that the stud is seated properly.... napa gave me the wrong stud... idiots! had a bit of an issue. my 2 cents Link to comment Share on other sites More sharing options...
jtdesigns Posted December 12, 2008 Share Posted December 12, 2008 I had a wheel stud strip out on my CJ,,(the stud was turning with the lugnut) took it to a shop and the @$$wipes torched it off,, along with a huge spot on the sweet chrome cragars it had... :rant: Link to comment Share on other sites More sharing options...
knightrider Posted December 13, 2008 Author Share Posted December 13, 2008 Okay......after fighting with seating the new studs, I paid out the $103 at o'reillys and got a new hub.......IT WAS FRIGGIN easy. I was thinking the old one was gonna be a booger....... Just want to make sure everything gets tight this time. Thanks for all the help fellas. Link to comment Share on other sites More sharing options...
