1984 J20
Leehi417
i recently sold my comanche ( there wasnt much left of the comanche... tires suspension and body ) for $100
and found my new toy a 1984 Jeep J-20 3/4 Pickup for $400. the guy i bought it off of was moving and needed
it out of his yard asap. he wanted $750 but i got him down to $400. its been sitting for 8 years but is in real good
condition surface rust here and there but its a beauty.
Specs:
5.9L AMC 360
Bored .30
Hedman Headers
aftermarket cam
2 bbl carb
Dana 44 front
Dana 60 Rear
Future Plans:
1. Get it running good and street worthy
2. Paint it something other then Red
3. 4'' Lift
4. 1'' body
5. 37'' tires
i pulled the plugs and wires,
changed the oil
got a new ignition coil
new battery cables
i sprayed inside the spark plug holes
one step down at least i know the starters good
next i plan on getting new plugs wires and distributor cap
along with belts a new radiator and hoses.
then i try firing her up and try to bring this old
lady back to life.
Thanks i been searching for some good websites.
i found one that seems to have good stuff if you FSJ guys wanna check it out
http://www.bjsoffroad.com/cartgenie/sub ... ategory=18
work slowed down and I'm running out of money :headpop:
so i have to hold off on a lot of the things i wanna do but
the other day i got the new plugs wires and distributor cap.
drained the old fuel out of the tank.
next plans are to get new belts
radiator and hoses.
does anyone have know a really good fuel cleaner to break up
the crap that might be sitting in my fuel tank?
My J-20 pulled an overloaded big U-Hual from Utah to Maine in 1985 and got 15-18 mpg all of the way.
Great truck and when driven in Boston "rotaries" (sort of like "Rollerderby" with cars) the turbo Saabs could not get out of my way fast enough.
To clean and re-seal your fuel tank, I would suggest going here.....
http://www.por15.com/prodinfo.asp?grp=TS&dept=12
Buy a quart of Tank sealer, a gallon of Marine Clean, and a gallon of Metal Ready. Follow these directions....
http://www.ratwell.com/technical/FuelTa ... ation.html
Welcome to "the dark side". I own a 76 J-10. I bought it in October 2000. Put alot of blood, sweat & money into it.....I still love it....even though it's been off the road (not in a good way) for a couple of years. That's why I bought my Comanche, that and a real good price. The J-10 will come back to life!!!!! If you don't know about this site, check it out asap; http://www.ifsja.org/forums/vb/ I can't say how much I've learned from them. I'm on that site also. Good luck my friend, look forward to seeing posts from you. Jim
  pineymike said:
here's mine I've collected most parts I need to rebuild it.;
That one looks like it survived the paintball warz! :rotf:
Image Not Found
'76 J10 shortbox (soon to get a Chev stepside to replace the rusty original)
Image Not Found
'73 J4000 that I rolled almost 2 years ago (parts live on in the '76 above)
'84 J10 7' bed with SOA 4.0L (getting the 4.6L stroker 6 once I find time to assemble it) AW4, NV241 OR, Ford D44 front and J20 rear with 4.10s (those are old 33" tires on it)
'83 J10 longbox 4.2L/AW4 (was T5)/NP208J Soon to be for sale
Image Not Found
My '87 Comanche on 33/10.50/16s (ZJ rims and Metric tires) Sadly I couldn't afford new ones when they wore out.
The '86 Comanche is posted in another thread (one for sale)
i fired the truck up today, she lives again. added some fuel cleaner and fuel
and she fired up after the third try. after sitting for 8 years it good to know
she works. works still slow so i can't do the things i wana do but ill keep
you updated when something happens. she sounded nasty, if i can find my
Those autolite carbs are not the greatest set ups but are pretty easy to rebuild and can be made to run decent. Be sure to set the float level correctly and to use compressed air to blow out the passages.
They tend to "mung up" when they are fed dead old rusty gas.
My 77 J-20 had a T-18 in it.
