dirtlord420 Posted November 9, 2008 Share Posted November 9, 2008 this is for my 4.0 on the passenger side. so @$$ clown put a longer bolt in there. i don't even know how they could have put it in. i just can't get it out. does the oil filter neck come off? my other option is to cut it out. i just don't see how i can get this out. the head of the bolt is toward the oil filter and the other end stick out about 1in. what are my other options here? Link to comment Share on other sites More sharing options...
Redramman Posted November 9, 2008 Share Posted November 9, 2008 :dunno: Does the motor mount bracket also un-bolt from the block? Oil filter neck? do you have an oil cooler ? Link to comment Share on other sites More sharing options...
fiatslug87 Posted November 9, 2008 Share Posted November 9, 2008 does the oil filter neck come off? The oil filter neck can be removed. There's either a Torx or hex head bolt that runs through it perpendicular to the block. If you do end up removing it, you should replace the three O-rings that are in there to avoid leaks. Link to comment Share on other sites More sharing options...
mfpdm Posted November 9, 2008 Share Posted November 9, 2008 Yep, the @ss clown was the engineer that designed it. :yes: You have to remove the oil filter neck to pull it out. If your pulling the engine, it's just as easy to unbolt the mount from the frame. :cheers: Link to comment Share on other sites More sharing options...
CWLONGSHOT Posted November 10, 2008 Share Posted November 10, 2008 :agree: :agree: :agree: :shake: :shake: :shake: :D Link to comment Share on other sites More sharing options...
dirtlord420 Posted November 10, 2008 Author Share Posted November 10, 2008 will autozone carry these o-rings? am pretty sure the mount has been replaced before. unless the stock mount has painted fluorescent orange. i just don't see the engineer using a bolt that long. anyone know what size the bit is on the filter neck? thanks Link to comment Share on other sites More sharing options...
offroader461 Posted November 10, 2008 Share Posted November 10, 2008 Get the o-rings from the dealer only....they auto zone one will leak..trust me i know :headpop: Link to comment Share on other sites More sharing options...
mfpdm Posted November 10, 2008 Share Posted November 10, 2008 i just don't see the engineer using a bolt that long. Welcome to the wonderful world of Jeeps. :D The motor mount bolt is 5 3/4 in. If yours is longer than that, then it probably was replaced or Jeep did what they normally do. Use what they had on hand. On the 4cyl, I had to remove the altenator to get it out. Thought once out, I'd just put it in reversed, no the oil filter was in the way. The bolt is a 5/8 in Hex on the filter neck. :cheers: Link to comment Share on other sites More sharing options...
dirtlord420 Posted November 11, 2008 Author Share Posted November 11, 2008 thanks. i trired auto zone guy looked at me real funny. then i was like am better off getting factory. it seems like everything i get from auto zone leaks. plus i don't like dealing with the idiots. Link to comment Share on other sites More sharing options...
