ejndssn Posted November 7, 2008 Posted November 7, 2008 I'm am about to receive an 88 XJ with 20k on the jasper engine. the own believes that SNS has gone south and I proceeded to ask what made him think so :hmm: . If you get it out of the garage its yours. My first trouble shooting is to see if it turns over and i'm already suspecting that its the CPS and i can pull one here shortly. what else should i look for besides the hum from the fuel pump. I hoping that this will an easy fix. team comanche club what's your thoughts :cheers:
pingpong Posted November 7, 2008 Posted November 7, 2008 Like you said.. first listen to the hum of the fuel pump. Then since its an automatic try moving the shifter around inpark, and nuetral to see if it will start.
reson46 Posted November 7, 2008 Posted November 7, 2008 What is an SNS? What specific problems are you having? Does it turn over, just not start? Will it not turn over at all? I would also check for spark. Make sure the distributor cap, rotor, spark plug wires, and coil wire are good. Willy
pingpong Posted November 7, 2008 Posted November 7, 2008 I think he meant to type NSS not sns :dunno:
ejndssn Posted November 7, 2008 Author Posted November 7, 2008 i was thinin like baba louie safety neutral switch thanks pingpong for understanding the spanish mind :rotf:
reson46 Posted November 7, 2008 Posted November 7, 2008 What is it doing? Is it not turning over? That can be caused by the NSS. This shows you what needs to be done to clean the NSS. Willy
Pete M Posted November 7, 2008 Posted November 7, 2008 NSS cleaning how-to: http://www.jeepin.com/features/nss/index.asp
ejndssn Posted November 9, 2008 Author Posted November 9, 2008 What is it doing? Is it not turning over? That can be caused by the NSS. This shows you what needs to be done to clean the NSS. Willy :dunno: this is what the owner is telling me and i need to get a chance to look at it and hopin its a simple fix like the CPS and if i had to clean ths NSS hope to find one at the JY that's a direct replacement :idea: and see if that does the trick and call it good :cheers:
Eagle Posted November 9, 2008 Posted November 9, 2008 I would say to just ask the owner if it turns over or not, but I've become aware in recent years that there are a LOT of people out there who don't even understand what that means. To far too many people, "does not start" is the same as "does not turn over."
ejndssn Posted November 12, 2008 Author Posted November 12, 2008 I would say to just ask the owner if it turns over or not, but I've become aware in recent years that there are a LOT of people out there who don't even understand what that means. To far too many people, "does not start" is the same as "does not turn over." what i have recommended was to swap batteries and give it a try and guess what she started and in my drive way :banana: i'm still going to check it out some more. :cheers:
FxRacing282 Posted November 13, 2008 Posted November 13, 2008 a wire with clips on the end can fix the NSS switch problem. well. tell you if thats what it is.
