removing the AT shifter handle. Top piece only
Ya know, I have looked in all the FSM's I own for that answer, 'cause I need it as well.
I pulled the right end (non-button end) cap off and then tried pushing the exposed white plug. It released the push button on the other side, but did not release the top part of the T.
Hopefully one of these really smart guys will come along and answer this one :popcorn:
Yep, just yank it. :D
For best results, put on foot on the passenger side and one in the drivers side, stand straight up over the shifter, and yank as hard as you can.
Once you regain consciousness, go get some ice for your nads. :eek:
J/K :D
I found it best to put the shifter in 1 and then pull it. Works really well in an XJ because you can get in the back seat, but does work just as good in the MJ.
:cheers:
