carnuck Posted December 18, 2013 Share Posted December 18, 2013 The spline that goes through the clutch (the trans input shaft) can be one of 2 different diameters. Older, smaller one is the same as BA 10/5 but the newer one is larger and won't fit. Not sure what year they did the change. Link to comment Share on other sites More sharing options...
MancheKid86 Posted December 19, 2013 Share Posted December 19, 2013 ***edit, post stated above already*** Link to comment Share on other sites More sharing options...
Ant_mant Posted September 30, 2017 Share Posted September 30, 2017 Great write up. Thanks. Considering doing a Peugeot to ax15 swap. The ax15vis out of a 92 jeep Cherokee and going into an 88 Comanche. Looks like all I need parts wise is the pilot bearing from a 74 cj? Link to comment Share on other sites More sharing options...
Skorpyo Posted October 2, 2017 Share Posted October 2, 2017 On 9/30/2017 at 9:44 AM, Ant_mant said: Great write up. Thanks. Considering doing a Peugeot to ax15 swap. The ax15vis out of a 92 jeep Cherokee and going into an 88 Comanche. Looks like all I need parts wise is the pilot bearing from a 74 cj? Just did mine, you'll want a pilot bushing, not bearing. I ordered mine from rock auto along with a nifty tool that threads into the old bearing and has a grease fitting. It allows you to pump grease into the opening and drive out the old bearing. Be sure to take your time when removing the old one so you don't mar the opening and when putting in your new one use a wood dowel as a drift since it'll be brass and will mar easily. I used an old broom handle that I cut and ground smooth to install the new one. Just take your time and you'll be good! Link to comment Share on other sites More sharing options...
