mjdoa Posted September 8, 2008 Share Posted September 8, 2008 Had a driveabulity problem,the longer the truck ran the worse it ran,til it would hardly accelerate at all. Bucking and missing under acceleration. Pulled the fuel pump yesterday,everything is covered with rust,sock about plugged. New pump,new sock,runs fine.But the tank is full of rusty sludgy stuff,so it won't last. Now,if I take the tank down,can I clean it acceptably with say my pressure washer,and can I use a rust stop product inside the tank? Thanks. Link to comment Share on other sites More sharing options...
Pete M Posted September 8, 2008 Share Posted September 8, 2008 If I was going to the effort of dropping the tank, I'd just bite the bullet and buy a new tank. :( At least then you'll know it's clean inside. Link to comment Share on other sites More sharing options...
mjdoa Posted September 8, 2008 Author Share Posted September 8, 2008 Not what I wanted to hear, but thanks. :cheers: Link to comment Share on other sites More sharing options...
maddzz1 Posted September 9, 2008 Share Posted September 9, 2008 You shouldnt have any problem cleaning it out. I would just make sure it was completely dry before closing it up and re-installing. You could coat the outside with por15 or something but i wouldnt put any rust preventer on the inside Link to comment Share on other sites More sharing options...
Wildman Posted September 9, 2008 Share Posted September 9, 2008 If your getting that much rust inside the tank, you need to find the source. From the filler neck, or from the tank it's self, and if it the tank, it's not going to be much longer before you start loosing that expensive stuff that you "pump" into the tank :cry: I know you don't want to hear it.......but time for a new tank. But the good news........Raybuck Autobody Parts, have really good prices on New gas tanks ;) Link to comment Share on other sites More sharing options...
mjdoa Posted September 9, 2008 Author Share Posted September 9, 2008 Actually.the outside of the tank,and truck for that matter,are relatively rust free. That's why I'd rather not replace it. Unlike most of you guys,I'm in So Fl., the truck has been here it's whole life. We don't get much rust like you do up north. I think the main water intrusion is from wheeling, every time I go I change engine,trans,transfer case, both diff's if it's wet riding.Evidently some gets in the gas tank too.I'll see if a vent hose might be cracked or off. Thanks for the advice. :cheers: I'll try to find some Por15. Never heard of it until I started Jeeping,anyone from the south know where it's available? Paging Dr. TAZ? BTW.not trying to fudge.If it's too nasty I will gat a new one. Link to comment Share on other sites More sharing options...
