SOA/LCA questions
I think I'm going to spring over the rear of my comanche and put 4.5 inch coils up front will it sit level with 4.5" coils? and what about the lower control arms will they work for now or do i need to get new ones? and this is a 2wd comanche will my old driveshaft still work? does the tcase have to be droped? I'm going to be running 32's o AR 15x8 black steel rims
-Your driveshaft should be fine, just install new U-joints.
-You don't have a t-case, and even if you did, you won't need a drop kit.
-4.5" coils can work just fine with an SOA conversion.
-You'll need much more than just replacement lower control arms. Shocks, trac bar, brake lines, etc all need to be replaced.
I'm SOA with 4wd spring packs in the rear and it sits slightly tail high with 5.5" coils. Sits level with a slight load in the bed like an axle.
I agree, 5.5" coils and a spring over/factory leafs looks right to me.....but as Pete said, the 2WD leaves seem to be about 1" lower...so you may get a nice look with only 4.5' coils in your 2WD.
I prefer that slightly higher in the back look, its as pu should be IMHO.
CW
