kar120c Posted August 24, 2008 Share Posted August 24, 2008 I've got a 91 2.5l that I'm fixing up. The engine had approx 230k on it but had really noisy valves and/or lifters. The oil in the pan was super clean and the cylinders look excellent. (pics below). My question is can I just rebuild the head and put new lifters on? I really don't see a need to do a full rebuild. The jeep was very well maintained by my father and didn't consume oil like other high mileage jeeps. Should I also pull the bearing caps while the pan is off? Link to comment Share on other sites More sharing options...
jtdesigns Posted August 24, 2008 Share Posted August 24, 2008 yeah you can just rebuild the head , and you could rebuild just the bottom end if you had too.. Link to comment Share on other sites More sharing options...
jeepman09 Posted August 27, 2008 Share Posted August 27, 2008 If it is not Broken don't try to Fix it!!! Link to comment Share on other sites More sharing options...
Eagle Posted August 27, 2008 Share Posted August 27, 2008 Looks pretty clean. I'd leave the bottom end alone, do a light clean-up on the valves, install new seals and lifters, and button it up. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted August 27, 2008 Share Posted August 27, 2008 Looks pretty clean. I'd leave the bottom end alone, do a light clean-up on the valves, install new seals and lifters, and button it up. agreed. however, I would pull the caps from the crankshaft (loosen but keep snug, then inspect one at a time) just to see if there is any wear marks...if there's wear and/or grooves on the cap-side of the bearing, then there will also be on the other side, and you need to do some work. not sure if i'd bother with the rod caps or not...idk. probably would not simply cause then you need new bolts for them... Link to comment Share on other sites More sharing options...
