ring and pinion fit
I just found a ring and pinion set on ebay for dana 30 and 35, which is what I have, 4.10 which is what I want. They are coming out of a 2004 TJ, will they work in my 89 comanche? If not, what year/model gears will fit?
Thanks in advance,
Tim
P.S. Pics will be coming soon of the comanche with new sound system, BB, grille guard, etc.
Rear will front will NOT. Your rear is a NON "C" clip D35 while the TJ is a "C" clip D35 rear, but that will make no never mind for the actual gears them selves.
Your MJ is a hi-pinion D30 front. Thats reverse rotation and not the same as the TJ's LO-PINION STD rotation.
CW
If you're looking for 4.10s, it can be cheaper to just get stock Jeep axles from the junkyard with 4.10s in them. Installation costs can be mind boggling. Plus, I can't condone sinking any money into a Dana 35 beyond new gear oil. They just aren't worth it.
I must agree :agree: go buy a used set of axles all ready set up 4.10. Also for a used set of gears that price is kinda high. The only advantage to using used gears is purchase price cost, and when they cost that much, you can almost buy new, and get free shipping. I think last time I checked on new d30 gears, they were around 119, with shipping. but thats been a yr or so ago, so prices might have gone up.
