alex_and_sean Posted August 13, 2008 Posted August 13, 2008 I have a 90 Comanche w/o AC but would like to put a system in. Does anyone sell a full kit (preferably a R134 kit)? Alternatively, does anyone know what the component list is that I need to get including change outs (do I need to change out the blower going from heater only to heat+AC)? Any guidance would be most appreciated. Thanks
Pete M Posted August 13, 2008 Posted August 13, 2008 These guys are both in the same boat. http://comancheclub.com/forums/viewtopic.php?t=11199 I have not done the conversion, but you'll need everything under the hood associated with the A/C, the A/C heater core box, and all the vacuum tubing and the controls in the dash. Basically everything that touches the A/C. Converting to 134 is simple enough so focus on getting parts junkyard that are in good shape. New parts are exceedingly expensive. It may even be worth it to buy a donor XJ that has working A/C and then sell off the rest of the Jeep when you're done.
broythomas Posted August 21, 2008 Posted August 21, 2008 does a 1991 have the r134? I'm considering buying a cheap messed up limited from a friend for skid plates, a/c, and leather seats with lumbar adjustment.
HOrnbrod Posted August 21, 2008 Posted August 21, 2008 does a 1991 have the r134? I'm considering buying a cheap messed up limited from a friend for skid plates, a/c, and leather seats with lumbar adjustment. No, R12.
broythomas Posted August 21, 2008 Posted August 21, 2008 also, does it matter that my 1992 4.0 doesn't have the electric fan? I have the old style mechanical one that spins all the time.
maddzz1 Posted August 21, 2008 Posted August 21, 2008 You will probally need to put one in. All MJ's with a/c came with the elec fan
HOrnbrod Posted August 21, 2008 Posted August 21, 2008 what is the 1st year of the r134? I think the 96 models were the first year for R134a for Chryco. Also X2 on adding an electric fan to your existing mechanical fan when you add A/C.
broythomas Posted August 21, 2008 Posted August 21, 2008 You mean put both fans in? Will they fit? Of course this is all future speculation since I now have to find a different parts rig.
HOrnbrod Posted August 21, 2008 Posted August 21, 2008 You mean put both fans in? Will they fit? Of course this is all future speculation since I now have to find a different parts rig. MJ's w/o A/C and/or the HD Towing package options did come with an electric fan from the factory. So you will have to add one in addition to the mechanical fan.
Pete M Posted August 21, 2008 Posted August 21, 2008 Converting a system from R-12 to R-134 is pretty easy so don't let that be the reason for passing up on an otherwise good deal.
mjeff87 Posted August 21, 2008 Posted August 21, 2008 small thread hijack..... Can you wire an e-fan into the stock harness if your MJ didn't come with one originally? I picked one up for my 4.0 swap and was planning to just wire it on a switch (via relay) in-cab, but if I can do it factory style and let the coolant temp control it I would. Jeff
broythomas Posted August 21, 2008 Posted August 21, 2008 What is involved in the change from r12 to r134? I thought the systems were different pressures and everything with different filling nozels.
HOrnbrod Posted August 21, 2008 Posted August 21, 2008 small thread hijack..... Can you wire an e-fan into the stock harness if your MJ didn't come with one originally? I picked one up for my 4.0 swap and was planning to just wire it on a switch (via relay) in-cab, but if I can do it factory style and let the coolant temp control it I would. Jeff Don't know about the Renix, but the wiring is there in the HOs, all except the short piece from the front bulkhead connector to the fan itself. And the fan relay is missing from it's socket in the Power Distribution Center. The trigger wire from the ECU to the relay coil is there too. 'Course, this doesn't help ya with the Renix Jeff. Is the temp switch bunghole free on your radiator? If so I'd stick an OEM switch in there to an external relay and wire in a manual over-ride dash switch. Or you could get the 1991+ Thermostat housing w. the bunghole and put your temp switch there.
mjeff87 Posted August 21, 2008 Posted August 21, 2008 Don't have a radiator yet, that's one of the few remaining things I still need. I was going to clean up the waterneck I have now (and install a new thermostat), but I might swap in a new 91+ housing and cap the sensor hole for now until I can figure out the wiring.
my87manche Posted September 5, 2008 Posted September 5, 2008 i'm about 3/4 done with my a/c install. pulled everything from a '94 chero. they are R134A systems. E-fan is the easy part, the mounting tabs are already un the rad. for a fact. fan, just use an toggle switch & relay. if you can,get the whole wiring harness for a renix w/AC. it will be much easier than making one as i am. i'm looking for a harness myself.
