which key fits in the glove box, ignition or door? i tried both but none seem to work. maybe the truck went through an ignition lock cyl b4 i bought it, in that case it would be on its 4th. :eek:
door key..mine is a PITA and it takes some jiggling to get it to turn :roll:
ok, got the key to work. it took me some jiggling as well to make it work... but i put some dry powder graphite lubricant in and now it turns smooth. that seems to be the secret for all of stiff lock cylinders jamminz.gif
next question regarding this problem... when i bought the truck the female side of the latch was unscrewed and laying in the floor of the glovebox. i looked at the male side and one of the posts that engages to latch shut is stuck in the closed position. whats the first step in fixing?
TIA
