MiNi Beast Posted July 18, 2008 Share Posted July 18, 2008 when you replace some worn part you make the other worn parts feel left out, so they act up more to get your attention. Have you replaced your tie rod ends? Perhaps a bad tire balance/flat spot? And ensure your track bar is good and tight. Link to comment Share on other sites More sharing options...
highlandjeeper Posted July 24, 2008 Share Posted July 24, 2008 We checked everything again and found nothing wrong. After inspecting the tires, we have concluded that one or more has a broken belt. They are the cheap Goodyear Wranglers found at such places as Walmart for +/-$50. I am going ahead with the lift and new tires and will see if all is well. Link to comment Share on other sites More sharing options...
mknherhappy Posted July 24, 2008 Author Share Posted July 24, 2008 We checked everything again and found nothing wrong. After inspecting the tires, we have concluded that one or more has a broken belt. They are the cheap Goodyear Wranglers found at such places as Walmart for +/-$50. I am going ahead with the lift and new tires and will see if all is well. Hope this works for you, I went through everything, things got better, but I still have a shake when I hit a rough bump over 55 mph. Hope new tires help???? Link to comment Share on other sites More sharing options...
highlandjeeper Posted July 25, 2008 Share Posted July 25, 2008 Should know after the weekend. Started on the SOA tonite. I will post in projects of the progress. Link to comment Share on other sites More sharing options...
