mjtjnj Posted July 7, 2008 Share Posted July 7, 2008 OK, as I collect parts and read on my engine swap before the day is here, I noticed there are two very similar temperature sensors, one on top, and one on the side of the intake manifold of the 2.5L. Are they the same part? I'm replacing all sensors when I do this swap, so there will be (I HOPE) no guesswork when it's time to turn her over! Thanks! Tom Link to comment Share on other sites More sharing options...
mjtjnj Posted July 9, 2008 Author Share Posted July 9, 2008 anyone? Link to comment Share on other sites More sharing options...
jaekl Posted July 9, 2008 Share Posted July 9, 2008 Where on the manifold? The coolant temp sensor is in the block next to the valve cover towards the rear of the engine (manifold side) Link to comment Share on other sites More sharing options...
jaekl Posted July 9, 2008 Share Posted July 9, 2008 sorry, I meant the sensor is in the head. Link to comment Share on other sites More sharing options...
mjtjnj Posted July 9, 2008 Author Share Posted July 9, 2008 Where on the manifold? The coolant temp sensor is in the block next to the valve cover towards the rear of the engine (manifold side) No, that's the temp sending unit for the gauge or idiot light. These sensors are on the top and side (driver's side) of the intake manifold. Link to comment Share on other sites More sharing options...
mjeff87 Posted July 9, 2008 Share Posted July 9, 2008 Tom, The one on the top of the manifold is the MAT sensor, has nothing to do with temp. The one in the side is what feeds info to the ECU. The sensor in the back of the head only sends signal to the gauge (or idiot light) in the cluster. :cheers: Jeff Link to comment Share on other sites More sharing options...
mjtjnj Posted July 10, 2008 Author Share Posted July 10, 2008 Tom,The one on the top of the manifold is the MAT sensor, has nothing to do with temp. The one in the side is what feeds info to the ECU. The sensor in the back of the head only sends signal to the gauge (or idiot light) in the cluster. :cheers: Jeff Thanks, Jeff. Any idea what part #? The MAT sensor and the coolant temperature sensor look IDENTICAL, and have the same connector. :???: Link to comment Share on other sites More sharing options...
mjeff87 Posted July 10, 2008 Share Posted July 10, 2008 almost the same part # too.... CTS - 3300 2383 (dealership) TS82451 (aftermarket, Neihoff, $22.99) MAT - 3300 2382 (dealership) TS81351 (aftermarket, Neihoff, $35.99) Careful if you try to swap the MAT, I snapped mine off clean with the manifold surface. I ended up pulling the guts out of it (luckily they didn't fall into the intake) then used a small fluted extractor to back out the threaded part stuck in the manifold. What I expected to be a 10 minute replacement turned into an all-afternoon affair :headpop: My CTS is still original, and I have to assume it's still working. Jeff Link to comment Share on other sites More sharing options...
mjtjnj Posted July 10, 2008 Author Share Posted July 10, 2008 Thanks, Jeff. Been there, done that with breaking things off. The whole engine is out, so if there's any problems, I'll have good access. Even got a spare intake! I bought the MAT online, saw a picture. It's not what I have. Someone just threaded in another CTS! So I've got two. Now I'll have one of each. Thanks Tom almost the same part # too.... CTS - 3300 2383 (dealership) TS82451 (aftermarket, Neihoff, $22.99) MAT - 3300 2382 (dealership) TS81351 (aftermarket, Neihoff, $35.99) Careful if you try to swap the MAT, I snapped mine off clean with the manifold surface. I ended up pulling the guts out of it (luckily they didn't fall into the intake) then used a small fluted extractor to back out the threaded part stuck in the manifold. What I expected to be a 10 minute replacement turned into an all-afternoon affair :headpop: My CTS is still original, and I have to assume it's still working. Jeff Link to comment Share on other sites More sharing options...
mjtjnj Posted July 12, 2008 Author Share Posted July 12, 2008 OK now I'm really confused. The cross reference shows a standard ignition part # tx-49. I ordered and got one of these today ($30 shipped) and it looks like the picture below. It doesn't look like the sensor threaded into my manifold! What is this part? Jeff the Niehoff # you gave me has apparently been superceded- - can't find it anywhere. Any thoughts? Thanks Tom Thanks, Jeff.Been there, done that with breaking things off. The whole engine is out, so if there's any problems, I'll have good access. Even got a spare intake! I bought the MAT online, saw a picture. It's not what I have. Someone just threaded in another CTS! So I've got two. Now I'll have one of each. Thanks Tom almost the same part # too.... CTS - 3300 2383 (dealership) TS82451 (aftermarket, Neihoff, $22.99) MAT - 3300 2382 (dealership) TS81351 (aftermarket, Neihoff, $35.99) Careful if you try to swap the MAT, I snapped mine off clean with the manifold surface. I ended up pulling the guts out of it (luckily they didn't fall into the intake) then used a small fluted extractor to back out the threaded part stuck in the manifold. What I expected to be a 10 minute replacement turned into an all-afternoon affair :headpop: My CTS is still original, and I have to assume it's still working. Jeff Link to comment Share on other sites More sharing options...
chicofuentes0224 Posted July 12, 2008 Share Posted July 12, 2008 That looks like an ignition coil for a wrangler. This is what a MAT sensor looks like. I got mine from BLHTAZ. Link to comment Share on other sites More sharing options...
Grant Posted March 31, 2011 Share Posted March 31, 2011 this is what I have dug up on the sensors etc for my 2.5. I am going to change all of them soon as I'll bet most of them are 25 years old Sensors Oxygen Sensor 5300-2106 STANDARD MOTOR PRODUCTS Part#SG20 Microprocessor 5300-4763 STANDARD MOTOR PRODUCTS Part # EM4763 Throttle Position Sensor 3300-0169 STANDARD MOTOR PRODUCTS Part # TH31 Speed Sensor aka CPS t073-9789 standard PC87T Colant Temp Sensor 3300-2383 STANDARD MOTOR PRODUCTS Part # TX28 the factory parts pages show these 2 numbers for th 2.5l I can not find replacements for either Intake Air Sensor 3300-2382 "suposedly Standard ax9" Intake Air temp sensor 5300-3938 ????? Link to comment Share on other sites More sharing options...
cz777 Posted April 1, 2011 Share Posted April 1, 2011 i use Teflon thread sealer not the tape on all sensors[water and intake air bond ] and water pump bolts ..just a tip from some very bad things of the past happenings ... Link to comment Share on other sites More sharing options...
