JeeperjohnfromPA Posted July 1, 2008 Share Posted July 1, 2008 So my Manche has been on the road for a few weeks now, it has a few minor issues I am trying to resolve, One of them is the reverse lights. ALL my tail lights, park,brake,flashers,turn signals work. BUT my reverse lights don't work. The bulbs look to be good, and the sockets also apear ok, I figure it must be a bad wire somewhere,, I had a problem like this on my YJ, which turned out to be a bad wire on the transmission, but that was a 5speed, and this is an automatic,, can anyone tell me where the wire(s) on the automatic transmission for the reverse lights are?? Thanks in advance. Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted July 1, 2008 Share Posted July 1, 2008 It's probably your NSS (neutral safety switch). The NSS is what controls the lights. If your careful you can clean them. http://jeepin.com/features/nss/index.asp Link to comment Share on other sites More sharing options...
jaekl Posted July 1, 2008 Share Posted July 1, 2008 This takes me back to my first replies. Check the fuse block. There is one marked trans. Even the manuals need this fuse to make the reverse lights work. Link to comment Share on other sites More sharing options...
JeeperjohnfromPA Posted July 1, 2008 Author Share Posted July 1, 2008 It's probably your NSS (neutral safety switch). The NSS is what controls the lights. If your careful you can clean them. http://jeepin.com/features/nss/index.asp Thanks Lead,, That information looks very helpful. adding it to the to do list this weekend Link to comment Share on other sites More sharing options...
Pete M Posted July 1, 2008 Share Posted July 1, 2008 Could also be the connector in the harness located right behind the drivers side rear tire. I've had corrosion issues with it. :( Link to comment Share on other sites More sharing options...
JeeperjohnfromPA Posted July 2, 2008 Author Share Posted July 2, 2008 Thanks Pete,, I'll take a look at that too. Link to comment Share on other sites More sharing options...
