mknherhappy Posted June 23, 2008 Posted June 23, 2008 Looking for those metal inner flare supports or brackets for the front of my 88 MJ. Anyone know where to get a pair? Thanks again for your help.
fiatslug87 Posted June 23, 2008 Posted June 23, 2008 PM BLHTAZ he could probably hook you up if you want new ones. You can also try http://www.chryslerpartsdirect.com/ go to the collision catalog then Fender, Exterior trim, Wheel flare, Retainer they're ~$15 each, then you'll need the nuts also (I assume). Not sure if they really have them, they list parts that aren't available sometimes. The fronts are the same as Cherokees so you can try a junk yard.
Eagle Posted June 23, 2008 Posted June 23, 2008 Keep in mind that they don't come in "pairs." Each flare requires three retainers -- all different part numbers.
BLHTAZ Posted June 23, 2008 Posted June 23, 2008 As far as I know, I can still get all the front retainers. With the CC discount, it will run you around $65 (plus shipping) for all 6 pieces. Retail they will cost you closer to $100.
