tprman
Everything posted by tprman
It's going to be both. I'm just looking for a new look on my MJ. After I get the lift on it, I'm going to do some gear work to it.
Thanks everyone that help me a lot. chjeeper give me a call when you are not busy.
I know this is a question this forums receives alot. But I'm going ahead and ask. I am wanting to run 33 inch tires on my 1988 MJ. What would be a good lift kit and how high do I need to go without cutting the front fenders.
I have a 1990 MJ 4X4 SWB 4.0. for $4200. Its located in Jasper GA. Shoot me a email at tprman@etcmail.com and ill send you some pictures. if interested..
What's a good high output alternator for a 88 MJ 4.0 with a 9000I winch and off road lights.
Black smoke coming out tailpipe.
tprman replied to tprman's topic in MJ Tech: Modification and Repairs
I noticed that line was not hooked up in the back of my throttle. -
I need a little help. I have a 1990 MJ 4.0. It started running ruff and black smoke coming out the exhaust pipe. It back fires and it sounds like it's skipping while idling. I tune it up and change the fuel filter but that didn't help. Any ideals. This MJ has been setting for 2 years.
I have one I just pulled out of my SWB MJ. I live in Jasper GA. $50. it comes with a tail gate protector. If interested my number is 770-387-7057. Tim
I have one for a short bed. I live in Jasper Ga. 30143. Give me a call 770-387-7057 Tim
Where would you mont another battery at on a MJ. Do they make 200amp alternators for MJ's if so where can you buy one at.
88 Mj Does Not Have Power Need Help.
Thanks. I went to the dealer and got a new ignition switch. Everything works better now. Thanks again for your help. Also I posted another question about wiring up a winch. -
What's the best way to wire a Warn 9000I winch. I have it wired to the battery. Every time I use my winch it pulls to much power from my battery and I have to stop so it can recharge the battery back up. I'm worry I will burn up my vehicles wiring harness. Any ideals.
You was right Gogmorgo I pulled the steering column down to check the ignition switch and noticed the brown wire had burn into the ignition switch. I took it out and noticed the ignition switch had been burn where the brown wire pugged in. Luck I had a old wiring harness from a MJ I am parting out laying around. I just replace the end and it started working. I going tomorrow and get a new ignition switch. Also would you put a braker on the brown wire to keep it from doing it again. Thanks again my MJ Brother. -
thanks ill give that a try. -
Nope it a automatic on the column. -
I need a little help. My 88 MJ does not have power to the blower motor, horn, wipers, turn signals and there no power going to the fuse box for blower motor. I do have power to other fuses in the fuse box but not the things listed above. Also my radio and cigarette lighter plug does not work. What may be the problem.
If anybody still interested I still have the bell housing set up. You can email me at www.tprmen@yahoo.com
What's gong on Shane. How the old MJ doing?
I have a bell housing and I think I have every else to, but I have to check. I am located in north Georgia. I don't have the slave cylinder. You can pick that up new at a dealer are a parts store. If interested shoot me a email at www.tprmen@yahoo.com.
I don't have what you are looking for but I have several other parts for a MJ if you need anything. I live in Jasper Georgia just north west of you.
I have a blue one down here in North Georgia if you every down this way $50.
I have a steering column out of a 88 mj if interested here in GA. $75 plus shipping.
I have lots of gray interior parts here in Georgia if interested. Email me what you need. tprmen@yahoo.com.
I have a BA 10 I pulled out of a 88 MJ 2wd $100 if interested. I live in north Georgia.
