jons87mj
Everything posted by jons87mj
  1. The fan pulls its power from the selanod under the hood. It has a fusible link and travels down and across the grill and back up to the relay. My truck was wrecked on the driver side front. It didn't look bad but it was just anof to cut the wire.
  2. ok so i replaced the wire to the alt to stud with 4gauge welding wire. and from there to battery with the same wire. i know have 14 volt at the battery when I'm off ideal. I'm going to do the grounds this weekend and see if it helps. thanks for the reply :)
  3. yes at the battery with it charing is 13.23 volts and i changed the alternator with a 200amp one (my buddy works at shop that rebuilds them)
  4. My 88 mj will only charge when you barely get it off ideal. When it does charge it only around 13 volts. I never had a dead battery from this but I feel something's not right. So what I'm asking is. Is this right are do I have a wiring problem? Any help would be great:D Thanks:)
  5. Hello:). I picked up a 96 jeep cherokee and the guy pulled out the factory steering colum and put in an older one. He got some of the wiring right but then some of it is not. Does anybody have a wiring diagram and know what wire does what on the 96 wiring? Thanks Jon
  6. With the sensor that low the coolant will cool down befor it reaches the senser. If you move it up to the thermostat housing then it will read the hotter coolant and will turn on sooner
  7. jons87mj
    Cargo Light
    Bump :)
  8. jons87mj
    Cargo Light
    Hi. I'm looking for a cargo light to put in my truck. I have the switch just need the the rest Thanks :)
  9. You will also need the speedo cable and the speed sensor that goes on the cable
  10. When I toke the swb skid off I broke all the bolts so I would assume that it has never been off befor. And it did not have the plastic skid in between the two
  11. Thanks for the replays :) ill just try and find a factory one. Seems like to much work to make the one I have work. Thanks again :)
  12. Really would appreciate any help with this:)
  13. Hello. I picked up a swb gas tank skid plate and was going to copy it but make the new one long so it would fit my lwb truck. But it looks like the mounting is different in the back. Does any body have pics of a lwb skid plat and how it mounts on a truck. Are if some one is willing to sell there's ;) Thank you
  14. I tested the fuel pressure and at idle its 30psi and when unplugged it goes to 39 and i did adjust the tps thanks Jon
  15. Hi. my 89 4.0L jeep mj runs good when its cold and when your driving down the highway, but when you stop for 10min or drive slow (like looking at new cars) and i get on the highway again it won't get above 45mph and it back fires and sputters. but if i stay below 45 it runs fine. i put a new distributor in it TPS CPS Coil and the box under it and the fuel pressure is 30 at idle and drops when you rev it up. Need help Plz Thank you
  16. mine is contected to the cruse control harnes.
  17. jons87mj
    Cruse Control
    Hi. I need the speedo cable from the transfer case to the back of the speedo. I'm adding cruise to my truck and need both cables and the speed senser that goes between the two. Let me know Thanks Jon
  18. The wiring in the colum the connecter broke and all the pens fell out
  19. Ok got it fixed. I checked everything like you guys said and it was the turn signal wiring. So I got that all replaced and works great now Thanks for the help
  20. hi my 88 manche has running lights and a left turn signal. i have no brake lights are a right turn signal. i replaced the brake switch and all is the same. i really need help fast I'm going to be driving it around noon tomarrow and would like to have every thang going thanks Jon o ya this is the back of the truck. everything in the front works
  21. the mobile site is amazing :rotfl2:
  22. i have a set on my mj and love them :yes: worth the money and i can get you a pick of them later if you want
  23. idk but if your unscrow the nut on it there is a slid in it and it rides on a stude made to the nut and mine was slide forward and made the brake light come on. i don't know its just what i found inside of the block. but the spare one i had everthang would move and the light went off :dunno:
  24. hello :D and the pedal for me goes down 75% then gets hard :dunno:
