bmyohn
bmyohn's Achievements
Can Spell Comanche (2/11)
U-Bolt Elimanator install
bmyohn replied to MiNi Beast's topic in MJ Tech: DIY Projects and Write-Ups
Here's a pic off of my rig. Ideally, when welded on you will not have a shim in place like I do, but when I had the welder weld them up I forgot to mention he should compensate for the 4* shim. -
It eliminates the use of a u-bolt...what that means is that on stock setups a u bolt wraps around the axle and on the end of the u-bolts is a plate that sandwiches the leaf springs in place on the perches. What a U-bolt eliminator (UBE) does is it takes away these u-bolts and uses 4 grade 8 bolts that hold the leaf spring in place on the perch. What's not pictured in this write-up is the top plate that the bolts attach to. Essentially this setup is arguabley stronger then u-bolts as well as a safe way to lift your vehicle (safer then blocks). They can be found in a 0.5", 1.0", and 1.5" lift flavor. Clear as mud? -
JF is Vbulliten
I've bought from Motion many times. On my last purchase I bought a CB radio mount that attaches behind the driver's side tail light. I couldn't get my CB tuned in right and called MO customer service. They talked me step by step on rewiring my CB. When that didn't work fully, Rebecca contacted numerous Radio Shops in Bloomington on my behalf to get my setup working correctly. They have gone above and beyond all my expectations everytime I have dealt with them. This company will definitely be getting another order from me in the future. -Brendan
Good choice with the UBEs. I have some on my XJ soon to be transfered over to the MJ and I love them. -
1989, MJ, Sport Truck 2.5L 4cyl / AX4 / N/A / N/A/ D35 / SWB Build date: 12-89 Current Location: Bloomington, IN Status: In salvage yard Notes: No tail lights, intake maifold, exhaust manifold, interior is torn apart, bed is clean though Current owner: JB's Salvage - Bloomington, IN
I just got my Comanche undercoated at Ziebarts with their sound deadining application. For $180 and lifetime warranty against the product chipping off its not a bad deal. It's plenty thick and should last a long time. I am contemplating doing it to my DD as well (2001 Dodge Rams 2500 CTD), just to see if any noise is actually reduced, the MJ isnt running so i can't really tell the benefits from that. But for a rust preventer, when applied correcetly can work wonders.
Got the bed removed today as well as the gas tank. Overall the bed is in alot better shape underneatht then I was expecting. There isn't any rust on the underside of the bed, but just a little bit of rust on the shock mounts on the frame. But nothing a wire-wheel can't take care of. The plan is to wire wheel off the rust on the frame, take it to the power-washer and get all the grime off of it. Maybe hit it with some primer then take it to Ziebart's to get the under-body covered. On to some pics: (overall, it is pretty clean) Gas tank has some surface rust, but should clean up just fine. Anyone want to turn this into a 6x6??
I definitely get where you're going with that. My only two big concerns would be the trans and TC. The axles will be coming out of my other XJ (D30/Ford 8.8"), and depending on the condition of the interior which I haven't seen yet I may swap seats over too. But then again the longer I wait the better the deal I will find, ideally I would love to find an XJ with a manual transmission to swap over. I just have to find the right deal and I'm in no rush to get it done
I think that I am going to do the swap on my own. I just started as a shop hand in a marina and the techs that work there that I've known for a long time said they could help me rebuild the motor into a stroker at some point. If I got the machine work done they would help reassemble the motor with me. So i'm not too worried about the mileage on the motor (but the trans may be an issue).
Quick update: Today, I got the dash and all wiring pulled from the interior. Also pulled the driver's side door. I also noticed some more rust underneath the padding behind the pedals, but it isn't too bad. I also have a lead on an $800 - 1999 XJ with 242k on the clock, the owner is supposed to email me pictures of it soon, so well will see if we have donor vehicle in the next few weeks. Up till then, I am going to try and get some front floor pans ordered and get the rest of the engine bay washed up so I can get it painted up.
Man you were right about those defroster screws, they are a pain. Rather then fuss around with yanking the dash down and trying to unscrew those bolts, I am just going to pull the windshield since it has a crack in it and needs replaced anyways. Thanks for the quick list, it helped a bunch!
I am in the process of removing the interior out on my 88 MJ and I am having some trouble removing the dash. I was wondering if there was a write-up floating around on how to pull it out. Thanks! -Brendan
