Yellowoctupus
Everything posted by Yellowoctupus
  1. Ah cool, thanks for the PDF and the tear-down post. I was searching variants of "Carbon Canister" instead of charcoal, didn't come up with that one. So, the canister is vented to the atmosphere from that bottom tube (which sounds obvious now, forgot about that open hose) so there must be an ECU controlled solenoid valve that is missing in these diagrams between the canister and the intake manifold, unless it's just drawing through the carbon canister anytime the engine is running??
  2. This is my rough understanding on how EVAPorative emissions controls work: When the gas tank heats up (while the engine is turned off), the sealed gas tank should slightly pressurize, and the escaping fumes will be captured in the carbon canister. This canister must be vented, otherwise they'd both pressurize together. It appears that the larger line going to the air cleaner is where this vents according to the diagram below. Is there a carbon canister purge valve I'm not seeing below? Wouldn't the carbon get saturated at some point unless it's subjected to fresh air being pulled through by the engine vacuum? (Disclaimer: I'm trying to mate the AMC Carbon Canister from my'87 4.0 MJ to my '02 Silverado 5.3 LS swap, so I'm trying to understand BOTH systems first.)
  3. Grease guns can produce a LOT of pressure, and auto parts stores sell a number of adapters you could try to go from Zerk (1/8" npt, for instance) to flare.
  4. The old timer I bought the truck from originally requested I remove them (as it's still an active business). He was probably concerned it could attract negative attention if I robbed a bank with it, or was caught hoon-ing around town or something. I told him it was going to Guam, so he was ok with the decals staying on. Some guy in MA contacted me trying to just buy the doors off it after I bought the truck. If they weren't rust free, I might have considered it, but they're super clean still.
  5. The hand painted logos on the doors were rapidly coming off, so I carefully washed it, and clear coated them, to preserve them a little longer. Took 1 rattle can, 3 coats on each side. As soon as I get our household goods here, I'll wire wheel those nasty looking rust stops to keep it from getting worse. I have no plans on painting the whole truck now. I'll just keep up on the little rust spots one at a time. Helps with the 'sleeper' look too.
  6. Yeah.....so one of the lines stuck to the tube nut when I went to remove the old expansion valve block and twisted it right around, before I realized what was happening. It's bad. I'll post up a photo sometime. No bueno. (There, only 6months late on finding that photo!)
  7. Awesome. IMO how all forums should be to fix errors and omissions, but... they're not.
  8. Thanks. In the past I've done the day by day build logs, but as long as I can edit the 'old' posts for a while, it will be easier than scrolling through pages and pages of updates to find details like part numbers, etc. How long do they stay editable? Truck's here! Paint is as-is at the moment. That will be a 'someday' project. Which as you mention, may end up being sooner than later with the salt in the air. I did use some Rustoleum around the windshield area, as there was some surface rust when I removed the old, cracked glass. We're focusing our house hunt on places with a 2 car garage, so hopefully it'll be stored inside most of the time. I'm not planning on selling this one; hopefully it will be a long term daily driver/project. Radiator, I'm going to give it a go with the stock radiator for now. Hopefully it turns out to be ok, if not I'll cross that bridge when I get to it. AC, I tried REALLY hard to get it straightened out before I got here, but apparently I now need to replace the evaporator which means pulling the dash apart. FOR LIKE THE 50th TIME. But I have an evaporator coming with the rest of our household goods in a few months.
  9. They're actually hand painted! I'm going to try to very carefully clear coat the doors to keep the paint from coming off any more than it already has. If you wash them, some white comes off. I do want to keep the advertising on there for now, probably right at the end of the hand painted era.
  10. Accessories: On Board Air: Using a WABCO 12V truck air suspension pump (we got a pallet of damaged ones shipped to our company and 'threw out' the whole lot....), and a chemical absorbent tank that I modified from another company I worked for, I put together a cheap on board air system. Not that I'm out 4 wheeling and dropping air in my tires for traction, etc, I ust like having a portable air system for those 'just in case' instances. Camper Shell: The longbed Comanche has a unique 7'6" long bed, so there's no other caps (ie from an S10, Ranger etc) that will fit the bed properly, as it might on the shortbed models. I picked up my cap for $100 in almost the same town I bought the truck from, and from the same area that the Colorado came from. All ~5hr round trips. Anyways, the cap was in good shape, no broken glass or other major damage. The seal setup I picked up included bed clamps. From a US based company, Extruded Solutions. I liked their automotive door seal style EPDM dual bulb seal for the bottom of the cap. Should last forever as long as I don't damage it taking the cap on or off. "ESI Super Cap Seal and 4 G-1 Clamps for Short Bed Pickup" Fuel System: (yeah, not an accessory, but it has to go somewhere...) Lesson learned #1, make sure you have gas in the tank before you change out your sending unit. Don't ask. #2, the tank rollover valves gaskets don't last forever. Replace them when the tank is out, if you take it out as they're kind of a pain to replace while the tank is in the truck. I found a Dorman PN that does work (Dorman OE Solutions Fuel Tank Vent Valve Seal Grommet - DOR 926-820 ). There are other PNs that interchange (I removed from my MJ: Ford PN E3EC-9B076-AA, which may be the same as F6TZ-69B076-AA). AMC J536-0059.
  11. Air Conditioning ("Aircon" as it's known here in Guam) Swapped in an entire HVAC box from a '94 XJ my buddy had sitting out in a field behind his house. Blower was seized (swapped in the 87 MJ blower) and it turns out the evaporator tube nuts were corroded to the tubes, so when I went to remove the expansion valve block, I just twisted the heck out of the evaporator tubes. So, out comes the dash. Again. Sigh. It's convenient to get a 94+ as I BELIEVE that's when Chrysler made the change to R134a. - Compressor fits in the stock 02 Silverado location. It's not roomy, but there's enough room. Fixed displacement Denso 10S20F style compressor PN: FOUR SEASONS - 78377. PS: This unit has a Pink Label over port plugs, denoting it is pre-charged with 3oz PAG oil. (The Yellow sticker models have to be drained prior to filling. ) - Belt: CONTINENTAL - 377K4MK - Tensioner: ULTRA-POWER - 419109 - GM adapter fittings to go to standard lines: (careful purchasing these as there's different sizes) - Replacement evaporator (94XJ) PN: TYC - 97347 - Condenser (94XJ) PN: UAC - CN4174PFC - Lines (I purchased a Mastercool crimper to do this (PN: 71550 ). I bought a name brand model, so I can recoup most of the cost if I decided to resell it on eBay later.) All loose fittings and bulk hoses I purchased from Coldhose.com . Very quick shipping, etc. Compressor to Condensor - Condensor to Dryer - Dryer to Expansion Valve - Custom Evaporator to Compressor - - Expansion valve (94XJ) PN: UAC - EX9448C - Dryer (94XJ) : UAC - RD8310C - Deslugger - Four Seasons - 36141: As the compressor is low on the motor, it will collect excess oil over time, which is NOT compressible and can cause catastrophic damage if it's started up with a bunch of oil in it. The deslugger pulses the clutch a few times upon first startup to prevent this from happening. GPD has an online manual with refrigerant and oil quantities listed in it. I used a lot of '94 parts, but they should be the same as '95-'96, so I used those specs. '94 was a R12 changeover year, so the GPD manual says to refer to the underhood label... '95-'96 Cherokee 7.75oz PAG100, 32oz R134a '00-'02 Silverado 8oz PAG46, 29oz R134a GPD MANUAL That said, I'll use the oil recommended for the Silverado, as that should match the compressor that it's lubricating and match the charge to the Cherokee. I already had a set of HVAC gauges, but picked up a $60 vacuum pump shipped off Walmart+ which arrived super fast, hopefully you get more than you pay for. I used to have a really nice older industrial vacuum pump, but I sold it a few moves ago. I don't do AC all that often thankfully, so I couldn't justify purchasing a professional pump. Dryer is installed on the HIGH side of the system, with an expansion valve. Orifice systems use an accumulator, and are installed on the low side. Accumulator vs drier . This goofed me up at one point, as I installed two high pressure switches on the system initially. One on the compressor, and one on the drier. I'm keeping the compressor mounted one, but need to change a hose/add an inline fitting for the suction/low side switch. And in my rush/inexperience, I completely forgot to include a high pressure service port. I probably spent 10minutes rechecking all of my lines looking for one. Can't believe I overlooked it when i was rushing the system together last fall. Oh well, live and learn.
  12. Placeholder for electrical/wiring. Electrical Finally got around to taking a photo of the battery location. Plenty of room where a transfer case "should be". I used some steel from a spare receiver hitch I had laying for the two angle brackets it's sitting on, they're welded to the transmission crossmember.
  13. Transmission: - 5sp Aisin AR5: pulled from a 2005 2.8L 4-banger Chevy Colorado (see rusty orange truck in earlier post). Shifted smooth on a test drive, paid $700 for the whole truck if I remember right. - Adapter Kit: A few companies sell adapter kits for the AR5 to mate up to an LS, mine was from https://www.facebook.com/p/RedEagle-Race-Parts-100072094501809/ RedEagle Race Parts. Guy was really responsive during the order, shipped fast, high quality etc. No issues at all with installation. I did indicate the bellhousing to the adapter plate (optional) which was fairly straightforward, although a little time consuming. Do it once, do it right. Although bolting the bellhousing to the adapter plate by itself is enough to keep it from ever shifting or going out of alignment, I also put a handful of solid, small diameter (1/4?) dowel pins in to ensure alignment if I ever had to separate them for whatever reason in the future. This kit uses a Colorado slave with a spacer to get the overall height right. I would recommend making up some flex lines that adapt right from the slave cylinder. Fabbot has a few kits available or at least use as a DIY example. I drilled holes in the bellhousing, which also works OK, but it's real hard to get to the bleeder. Make sure you do OVERSIZED holes to be able to get a socket on the bleeder. I had to do it when it was in the tunnel which was CRAZY difficult and required die grinders most people would not have at home. - Driveshaft: I was able to retain the stock driveshaft, by purchasing an extended length driveshaft yoke as the stock yoke didn't have enough engagement in the transmission. Oddly enough, GM TH350's and a slew of other transmissions including the AR5 share the same slip yoke / output shaft splines, so I got this one from eBay (Mako-Driveshafts). Description: "2-3-6081X 8.000" Length extended Trans Slip Yoke 1310 series 1.176 x 27 Spline" The spline sliding interface isn't quite as smooth as an oem yoke, but it's acceptable. I think the stock Colorado yoke is 6", so this gives you 2" extra without having to have a new driveshaft made. **5/2025 update** after replacing the seal, it started leaking almost immediately. I initially attributed it to the poor surface finish of the yoke which I polished with 1000 grit sand paper). 2nd new seal, leaks again. With 0.5mi on it.) Turns out it's the welch plug that is pressed into the end of the yoke. I'll post pictures later, but I tried to seal it up with a smear of black RTV around the plug edges but it was difficult to access with the driveshaft in the truck. I may have to pull the driveshaft AGAIN to seal it up off the truck. Lesson, you get what you pay for. * UPDATE * over a year later, I pressure tested it and found a leak in the SIDE of the splined tube. I got ahold of the eBay seller and he sent me a brand new (slightly different design) replacement, free of charge. I'm pleased with their customer service to say the least. Will update on how it holds up. - Shifter. Currently, I am running the full height shifter. It's at a position close to the steering wheel, and the throw is reasonable, but I feel like it could be a few inches shorter. Definitely don't like the rubber vibration isolator that's in there, so sometime I'll change out the whole top half of the shifter assembly. it locks onto the lower part with a single set screw that Aisin or GM had Magilla Gorilla lock in place. So, the isolator style oem shifter top can be disassembled, by drilling out the 'pivot rivet' and then by wire wheeling the rubber off the steel sleeve. It's a 1/2" hole through the sleeve, so I jammed (I don't think I've even got shaft retainer Loctite on it yet!) a polished 1/2" aluminum tent stake I found in a field that I threaded to 1/2"-20 which is the same as a few knobs I've got laying around. Height is great, straight is best ( I tried a few 'bent' variants but they brought it back too far towards the seat). - Replace the output seal before the transmission's in. It's cheap and apparently when you ship it with a bottle of gear oil, Rockauto will change your shipment to ground and then it'll take FOREVER to get to your island cause it ships on a ship. Lesson learned. Seriously, this shipped on Jan 30th, it's now 3 weeks later and I get this message on the tracking (No ETA): "Your package will arrive later than expected, but is still on its way. It is currently in transit to the next facility." SURE it is.... FYI: WJB / INMOTION PARTS WS711009. (update: took almost 5 weeks, glad I ordered 2x).
  14. Prior to purchasing this MJ, I looked at a few other MJs including an LS swap that got started. He sold me the Novak mounts which bolted right up, and worked nicely. Novak does offer a lot of parts for the swap (including a $700 radiator!! ), but the motor mounts are all I used. All other parts used for the project are as OEM as possible for easy parts replacement, or 'non-wear' custom parts, like fuel rails, AC lines, braided fuel lines, etc. LS engine rundown: - Engine Started with an '02 Silverado 5.3. It appeared to be in VERY dubious condition ( I think it sat outside uncovered for a long time), so I bought a 2nd engine, an aluminum blocked '05 5.3 from a Trailblazer SS. Unfortunately it's got GM's Active Fuel Management, but hopefully that doesn't give me issues. It's a known problematic design. The aluminum block engine I got is year 1 for GM's Gen IV ECU, but interestingly enough it still has a 24X reluctor wheel like the Gen III engines. So, you can run the Gen III ECU with this engine. For better or worse. Seems to be more aftermarket support for the Gen III vs Gen IV, but I could be wrong. - Truck intake's too tall unless you chop into your hood or run a cowl. I found an LS1 intake on Marketplace, PN 1256333. They're surprisingly expensive, but this one came with a set of Racetronix fuel rails, and ARP intake screws for the same price as other bare intakes, so it was a good deal in the end. - '02 injectors (used OEM 25317628) Interesting story, I ORIGINALLY purchased some 'reman' OEM injectors from fuelinjectors-shop on eBay, but they ended up being brand new China knockoffs. I submitted a claim and eBay immediately refunded my $. Normally I check feedback but had forgotten to on this one. This seller had a LOT of negative reviews with this exact issue. Poor quality injectors, flowed all different, or stuck open, leaked, etc. - Fuel Rails, Racetronix, as are most of the -6 AN fittings on the build. Quality is good enough, price good, shipping fast, and they also had a few 'conversion' fittings I used to go from the OEM Jeep fuel lines. Fuel pressure regulator is in a housing made by Radium. Really cool piece, and it uses OEM Bosch regulators. Non-adjustable, and not SUPER high flow but there's no custom wear parts/diaphragms to go bad or that are hard to find when they do. PN 20-0014, Bosch 4Bar (60psi) regulator PN 0280160575. Mounts directly to the rail. - ECU '02 Silverado ECU reprogrammed with a 4.8L Manual base tune ( as there wasn't a 5.3 manual offered) Using Universal Patcher and PCM Hammer to read and alter the ECU program. Not terribly difficult but a bit of a learning curve if you don't do it often. Cleaned up entire harness (time consuming, but in the end worth it) bought a book to help determine wiring but after finding a few mistakes, ended up using the charts over at LT1swap.com https://lt1swap.com/1999-02pcmpinouts.pdf - '02 Silverado DBC throttle body, 2002 Silverado cable. Had to SLIGHTLY open up the firewall hole with a step-bit. Otherwise it fit perfectly. Also, I had to make / adapt a custom mount at the throttle body. - Cooling System - Stock "1994" Jeep radiator, custom stainless steel lower crossover tube, currently 1 OEM Jeep fan. I'm expecting I'll have to add a 2nd fan later. Bought a Matco vacuum bleeder to eliminate air pockets, retained front steam vents, which I plumbed into a splice connector. Instrument panel gauge's coolant temp sensor is also screwed into the connector. Upper hose is a 4.0 stock upper, lower two are 90° 1.5" ID. PNs Gates 20267 and 20065. Cheap on Rockauto. Water pump is from a 2007-2019 L92 (possibly also LS3). GM PN:12637371 - Motor mounts - Novak. Highly recommended. Yes, I'm sure you can make your own and save a few $$ but I bought mine used and it was money well spent. Everything bolts right up, drops right in place, sturdy build. 'Nuff said. - Belt System - manually tensioned alternator (homemade mount), Bando 580205 tensioner pulley. Belt Gates: K060625. - Alternator '05 Trailblazer (145a or 160a, don't remember which) - Power Steering Pump '02 Silverado. Pulley was too large and hit power steering lines at the box, so I used the '05 trailblazer pulley. I did have to space the pump back however to get this to work, and abandoned the rear 1 bolt stabilizer mount. Original pump reservoir leaked, so I replaced it with a parts store version (Napa or Oreillys?) Even after bleeding it it sounds really loud. Fingers crossed it works some more air out or something, as it's not confidence inspiring. Also hard to check PS fluid level as the alternator's in the way. I may tee into the return line with a clear section to make checking level/filling easier. - Exhaust manifolds - eBay China swap cast (steel/iron??) manifolds. They came with crappy fiber gaskets at the head, so re-used my cleaned up OEM MLS gaskets, and the collector gasket they supplied was a rubber o-ring. REALLY??? I purchased a few 'metal oring' style gaskets, and found one that works PERFECTLY in the groove they give you. MAHLE - F32568. These manifolds fit REALLY well. I did have to dent in the passenger's frame rail a little bit, but it was not bad at all. - Oil Pan - 02 Silverado, and pickup tube as well. Clears the front axle fine.
  15. Thanks! I'll send you a PM sometime. (or likewise, feel free to send me one!)
  16. The Jeep OEM driveshaft for the 2wd longbed is really weird. It's got some sort of a rubber vibration isolator captured between two tubes??? Can't say I'v e ever seen one like this before. Hopefully it holds up for me.
  17. 89 MJ, I saw some of his posts a while back, especially in regards to his tailgate straightening project. I'll have to look him up! PS, my Dad had a 1940 Chevy pickup that was in the family since '40. He lost it 2yrs ago when the barn burned down. What a bummer that was. He did end up with my '55 Willys though, so he's got a project to keep him busy in the wintertime!
  18. Dragged home this beaut of a '05 Colorado just for the 5 speed. The Aisin AR5 is supposedly similar to an AX-15, but it's a newer version, and can handle quite a bit of abuse. The truck was fairly rust free, with the exception of the frame, which came with free rust. It slowly creaked in half while I had it on the jackstands. Made a spooky sound. Sold the engine, and everything else I could to end up with a $0 transmission.
  19. About a year ago.... (2/24) my wife received orders to Naval Base Guam (deploying 12/24). We've been moving our fleet of cars around with us (more or less) for almost 20 years, so we finally decided to trim down the list to 1 car each. So, instead of choosing one to keep that I already had on the road, running driving, I very reasonably decided to sell everything and build up a V8 stick shift street truck to have road worthy before deployment. (To do so, I sold my '98 4.0 AX15/4wd swapped Cherokee, my 5.9L '55 Willys Wagon and my Supercharged 4.6DOHC swapped '78 280z. Some say I'm nuts. The others just silently shake their heads....) Anyways, I picked up a reasonably clean 1987 Long Bed, 2WD, 4.0 with the BA10 5sp. It barely ran, floors were gone, but other than the floors, it had very little rust. I got it from the 2nd owner who purchased it on 1988 with 1300mi on it, using it from then on as a 'shop truck' running parts and tires between his two tire shops on the Cape in Massachusetts. I got it at about 100k as it's been off the road since 1999. Yes, that's all original paint. From New England. Coming home from the Jeep Dealership. (Not actually purchased from this dealership, but it was a BRAND NEW dealership, and right across the road from where I picked it up, so I couldn't resist the shot.) Unloaded, made it home safe and sound. The Cherokees make reasonably good towing vehicles when equipped with a good trailer brake controller and a quality weight distribution hitch.
  20. Ωhm -- Thank you for sharing that electrical manual. I have a few others, but was missing this. Wish I had found it earlier!
  21. Just did this job today on my '87 MJ. Drilled out the body side to 5/16" with a nice sharp bit (drilled 9/32" first, then 5/16" (was worried they might be loose after drilling instead of reaming.. but the bushings still had to be driven in, so I guess it was close enough). Cordless DeWalt drill was used, no issues fitting the drill between the hinges. Used Hillman bronze bearings (available at most hardware stores). 1/4" ID, 5/16" OD, 3/4" long. $3.50 ea, so $14 per door. Cut 0.25" off each bushing, and installed two in each hinge. The hinges are 1" thick. Put in new 1/4" x 2" roll pins (ideal is 2.25" long, but 2" I think is fine). I also put a thin brass washer between the hinge parts to take some of the thrust load, they were pretty thin, forgot to measure them, but probably 0.020"? ZERO play now. Very satisfied on how they came out so far. I would have liked to try out the PN 8211 K&S metals brass tube, as it's only about $5/ft, but none of my local hardware stores had that PN in stock. Maybe if I have to do my passenger's door someday I'll try that out.
  22. Perfect timing for this question, as last week I removed my cracked windshield, and treated some minor rust on the windshield frame. I was under the impression that the 91 and up glass which takes the rubber trim was possibly a larger size than the 84 to 90 glass. I'm indifferent on whether I have the stainless trim or the rubber seal on mine, however was curious what the glass change was between those years. Thank you for verifying that the little weld studs could stay in the frame. Were they taken out of the design after 91?
  23. The 'forward position' refers to the fact that the shuttle valve will actually move towards the front of the vehicle. The right side of the picture is pointed towards the front of the truck.
  24. So, if I "stop ending" I'd be starting? Good catch, thanks. Here's the 'original' photo from this post: Definitive Comanche Brake Bleeding
  25. Hi Eagle, Please let me know (PM or reply) where you saw any typos and I'll edit the post. I transcribed it from a JPG posted here a few years ago that I could barely make out, so it's certainly possible I goofed something. Sorry fiatslug87 if it's a reposting, I kept finding various debated proven/misproven methods on bleeding I figured it would be good to have a 'sticky'd' post of the factory method to reference (whether it's the best/worst/omitting anything etc) as it seems to be a VERY common topic here.
