AnotherOldJeepGuy
Everything posted by AnotherOldJeepGuy
  1. Case in point, I suspect there is a how to use the forum, somewhere, but since I could not find it, I am having to post a new topic to ask either where it is. Or if nonexistent, request one. It took me, granted a new user, about 10 minutes to dig up what I previously posted. And another 5 minuted to figure out how to reply to it. I'm sure it's one of those things, easy to do once you know how. I am lacking in that "know how" so a tutorial of basic use would be extremely useful! Thanks, Guy
  2. Thanks Pete - that is a clever fix! And assuming I can get to the needle easily it would be a quick fix, that depends on if the plastic front can be removed without pulling the full cluster, TBD I guess. Thanks gogmorgo, I am not familiar with cruiser54 or MTS, but I am sure Google is!
  3. My fuel gauge issue is that when full the needle is around 1/4 tank distance beyond Full. The real problem is that the gauge read somewhere between 1/8 and 1/4 when I run out of gas. This operation is consistent, but I would still prefer having an accurate fuel gauge! All parts are original 1990 parts and there have been no modification done that I know of... The only work I know of was I had the ignition switch swapped out once when I though that was an issue with a start up failure. At the end of that repair my AUX position no longer works, but I didn't find out the AUX didn't work until months after the work was done since it's not something I use much. I also don't know when I first noticed the fuel gauge issue so I can't tie the two issues together with confidence. From the post above I can see that I should be able to test the gauge itself pretty easily if I get it out. I have noticed while surfing some it being said that removing the fuel gauge is a PITA, so before I start, any advice on what I am getting myself into if I want to pull it? Any thoughts on the potential relationship to the fuel gauge failure and the ignition switch swap? Thanks.
  4. Updated 3/25/2026 230,000 1990 Comanche Pioneer 2WD Original Owner
