Everything posted by NickyV
Turn Signals Malfunction in the Rain
NickyV replied to NickyV's topic in MJ Tech: Modification and Repairs
Ugh... Well this is embarrassing. I swear I checked the fuse, but I apparently didn't look very closely at it. The fuse wasn't blown, but one of the blades was terribly rusty/gunky. I just swapped it out with a fresh one and the signals started working again. I think there are two takeaways here. 1) Always rule out the fuse. For whatever reason, I still struggle with this one. I'm always imagining a more complex problem. 2) I really, really need to do an overhaul of the fuse box. Any fuse that has been in the fuse box for any significant period of time usually has gunk on it. What have people done in regards to improving their fuse box? Right now, I'm thinking that maybe I can clean it up and then figure out some way to put a cover over it. I wonder if I can find a plastic box with a hinge that I could modify and then place the fuse box inside of. That way if the master cylinder leaks in the future at least it won't drip directly onto the fuse box. -
It's been raining pretty heavy where I live and my turn signals have been acting up. I'm pretty sure it has something to do with water, and I'm wondering if anyone else has had this experience. The Symptoms: - Turn signals stop flashing entirely. The lights themselves don't flash and the interior indicators don't flash. I can hear a buzzing electrical sound down near the turn signal relay. - After driving for a bit, they start working again (signals and dash indicators). Like maybe something has dried out? - Hazard signals work -- both the indicators and the signals themselves. - All exterior lights work. It's just that the turn signal isn't working. - One more thing to mention: My turn signal stalk doesn't work quite right. When I turn left, I have to manually return it to the neutral position after completing the turn. When I turn right, it returns to neutral position on its own. The Background: - Imperfect Wiring Job: I've done a fair amount of work on my turn signals over the years. A few years back, I replaced the sockets for the bulbs, because I had the thing where the turn signal indicators on the dash stay illuminated. That was due to a bad ground in the socket. When I did that job, I don't think I did a great job insulating the wires. I only used electrical tape. - Upgraded to LEDs: More recently, I upgraded to LED on all exterior lights except the headlights. I also upgraded the relays to electronic relays with the pigtail ground wire. When I did that job, I had to replace one of the sockets, because I broke it during the job. On that socket, I did a better job with the wires, using shrink wrap. I only bring this up because one of my turn signals came back to life sooner than the other, and maybe it was the one that I did a better job of insulating... not sure. The Question: What is most likely? That something is going wrong near the relay, or that something is going wrong near the bulbs? Or... could it be that something is starting to fail in the steering column? I'm thinking that it's something near the relay. Maybe I have some moisture getting in through the firewall there. And, like many of us, my fuse panel has been seasoned in DOT 3 fluid over the years. Maybe it's time to finally take on the fuse panel refurb.
I've said it a few times now, so it's time to put up or shut up. I'm taking the plunge and starting a build thread for Old Red! The Basics Year: 1987 (The vapor barrier inside door was stamped with "Oct. 1986") Trim: Base (When I bought my MJ, it didn't even have a cigar lighter!) Color: Colorado Red (Original paint job... but someone may have done some touch ups along the way) Engine: 2.5L Trans: AW4 / 2WD Suspension: All stock... for now. Tires: 235/75R/15 Misc: Camper Shell (White) How It Started We bought the truck in August 2019. It had 113,000 miles on it and seemed to be pretty much "Base" stock. No power anything. I'm wondering if it even came with a radio. It has all the audio wiring, but there were no door speakers and whoever cut the holes for the 6x9s in the pillars did a sloppy job. How It's Going These days, it's a lot more driveable. I managed to mostly cure a case of death wobble with the help of a mechanic and new tires. We did a lot of front end work to address the DW. It now has power steering (not sure where all the parts came from... the mechanic did that). I've replaced all components of the clutch (also mechanic work) -- master cylinder, slave cylinder, clutch plates. I've done a lot of interior and electrical work: Full sound system with tweeters, doors, new 6x9s, and a sub. And I've driven it all around California: Over the sierras (through Yosemite), up to the Oregon border, all the way down to Death Valley and Anza Borrego State Park (inland San Diego County). What's Next There is still so much to do! Suspension, air conditioning, camper shell upgrades... I'll be posting some of my previous projects in the thread below.
Dangit. Well... at least I only put one of them in. And I ain't giving up just yet!
Reviving this thread because it relates to a project I just tackled over the weekend. I finally replaced my busted passenger side window regulator. Anyway, here's the TL;DR version of my question for @schardein or anyone who knows: Has anyone found window cranks that play nice with the Jensen Accusound grilles? Here's the backstory: I was at the junkyard a while back and I decided to get fancy and I pulled some Jensen Accusound grilles from an XJ in the JY. I liked the look of them. I have rectangular grilles covering the 6x9s I have in the pillars, so I thought, why not rectangular grilles in the doors as well. Suffice to say I had not read this thread. The window crank definitely hits the grille... well... more like skips off the surface of it. And actually, if I'm careful about it, I can apply pressure and kinda have the crank at an angle, so I don't scrape the grille. But this is not a good solution. Seems like it just needs a smidge more clearance. Then again, I'm not sure I got my handle on all the way. There seems to be more space between the door card and the crank than there should be. I tried giving it a few love taps with a rubber mallet, but I didn't want to damage the regulator I just spent so long putting in place. Here's my experience putting in the window regulator for those who find this thread in the future: I bought the replacement regulator back in like 2020-21 and had been dreading this job because I'd heard horror stories. But it actually wasn't that bad. Yes, I had to drill out the rivets, but all in all, it was a manageable job. Probably a full day of work for me and I'm still building my chops. Someone with more experience could do this in a couple of hours. To make life easier for yourself, make sure you have all your bolts ready to go ahead of time and beware that the brackets on these window regulators are held on by 35-year-old tack welds. One of the brackets broke after I had the regulator in the door. It was getting dark and I didn't want to pull it back out (I don't have a garage). Thankfully, it was the bracket at the top of the regulator. I zip tied the regulator housing to the bracket. I think this will be fine. If not, I'm going to have to pull it out... but I guess it will give me an excuse to finally start to learn welding. I replaced the rivets with short bolts and a combination of locking nuts, locking washers and Lock Tite. I do not want those things coming loose unless I say so! I'm planning to make a video on this and I will soon start my own build thread so I can share all the videos I make.
Project: Slippery Slope – a ’91 MJ runner
NickyV replied to Gjeep's topic in Member Projects: Your Comanches
Is the starter kill a security feature? I've been thinking about how to add an extra layer of protection to my MJ besides Ye Olde Club. -
What CC knows about stock Jeep radios
NickyV replied to NickyV's topic in MJ Tech: DIY Projects and Write-Ups
That’s great (hopefully!), @holoceneghost. I have no idea why that would have been the case for you, but back to what I was saying. I’ve made simple mistakes and I’ve also stumbled bass-ackwards into breakthroughs. I forget where it is on the forum, but there is a link somewhere to the “Electrical Troubleshooting Manual” in PDF form. I think I grabbed it from the user with the Taz icon (Tasmanian Devil cartoon). That manual is super helpful. -
@holoceneghost Apologies if I'm explaining things you already know, but... I've done a fair amount of tinkering with a number of these radios. Not as much as @Minuit, but a lot. One thing I can say is that I've made some simple mistakes in the past. One example of a mistake was only connecting power and speakers. I thought that would be enough to get the radio to work, but on some of these radios you must connect the antenna to even get it to power on properly. Sounds like you are past this step, but it's just an example. Connect everything! Another tip is to invest in a bench power supply and some cheap speakers plus all the appropriate connections. Troubleshooting on the bench is WAY easier. Trying to figure out issues inside the cab with the radio in the dash is no fun. Finding manuals for these radios is hard, in my experience. You might be able to find one on e-Bay. But you can also try the Internet Archive. They have a very large database of manuals. Searching it takes patience and isn't super intuitive. I just took a look and I was only able to find one manual. It was not the radio you have. But yours is on there! If you happen to make a breakthrough in how to find our radio manuals, please let us all know! -
Ideas Wanted: Softer Release of Parking Brake
@fiatslug87 - Thanks for the tip on that build thread. Fantastic work. I am not following. @DesertRat1991 - Guilty as charged. I'm always overthinking things! -
Thanks everyone. Glad I started this thread. I feel like I'm aware of just about everything everyone has said in the general sense. I know the rubber stoppers exist. I know they won't change how fast the parking brake releases. I know I can use a single foot on both the brake pedal and the clutch, but I've never been very good at that. I don't make a practice of using the parking brake to do what I'm describing, but every once in a while... Every once in a while I wish I had an e-brake like my old Isuzu Trooper had. That thing had a hand-pull parking brake that was pretty close to the shifter. My research shows me that certain years of the Toyota Hilux also had this style of e-brake. But I guess it's kinda rare in more modern trucks. It was cool though. To engage, you just had to pull back. To disengage, you would twist it, and you could let it out slowly by hand. There are two situations where I'd want to use this: 1) If I was parallel parked on a steep hill with a car right behind me. Here in the Bay Area, there are lots of places where this can happen. 2) One time I was coming out of Death Valley in the MJ. I was on a steep incline and I had to come to a stop. There was a cliff not that far behind me. Truck stalled. Then it stalled again. (I still need to replace the fuel pump because it still will stall when low on fuel and facing uphill). Each time I stalled it, I rolled back a little bit. It was all very nerve-wracking, because this was back when the parking brake didn't work. I ended up getting out of it with help from some friends, large rocks and a heaven-sent team of fully equipped YJs that happened to roll by. Don't know what would have happened without those guys. Anyway... for now, I'm going to cobble together a rubber stopper, and I'll keep thinking about other solutions to this rare (but stressful) predicament that I can sometimes get into. Good thing is, I now have the brake working. And if I'm ever in this situation again, I can tolerate letting the e-brake slam open. I'd rather smash my fingers or ear drums than roll bass-ackwards off a cliff. Lol. -
A month or so ago I finally fixed my floor pedal parking brake. I managed to do it without removing the assembly. I had to get innovative with an off-the-shelf spring from the hardware store (I cut it to fit and bent the cut end so it would hook around the pawl… TikTok link below). Now I’m wondering what those of us with working brakes do about how violently it snaps back when disengaging. Most of the time, I just put my foot on it and use that to guide it back up softly. But what if I’m using it to get out of a hairy situation on a hill? I have a manual and I only have two feet! I don’t need to do this very often, but every once in a while I get into a situation where I’m on a steep hill at a dead stop and I can’t really afford to roll back, even a little bit. Since it is rare, I guess it’s fine if the brake pedal disengages like a prize fighter landing a haymaker, but I is there something you all would recommend? Maybe just a thick piece of rubber for it to smack against? Is there a mod I could do that would allow me to release it gradually without the aid of my left foot? I’ve been trying to keep things as stock as possible, but it really makes me wish I had the XJ hand brake. https://www.tiktok.com/t/ZTMnQP25Y/
Power Steering Pulley Wheel 1987 MJ 2.5L - 5300 3805
Yes. The clicking was around on the old pump, too. I have a few updates after working on the truck last night: TL;DR: I think this is due to a combination of factors. Those are: A beat up pulley wheel. A belt that has suffered as a result of a beat-up and poorly adjusted pulley wheel. Engine compartment temperature. I am less sure now that getting the exact right part will make a difference, but I'm still on the hunt for the OEM part. Some Clarification: I keep calling this a "click." But that's it's hard to find the right words. It's definitely not a "squeal." It's not a "groan" or a "sigh." But it honestly might be a "chirp," rather than a "click." The Good News: Whatever we call this noise, I think I have succeeded in getting it so it doesn't make the noise when idling. However... The Neutral News: When I started it up this morning, it was making noise again... until it got warm under the hood. Then it went back to being quiet. So I think temperature is playing a role here. The "Meh" News: Once I get to about 20 on the tachometer, I start to hear belt noise again. This is with the truck in neutral. I'll drive it around this weekend and try to see what it sounds like under load. My Procedure: This might be obvious to the more experienced folks out there. But if you come across this thread, here's what worked for me. I still do not have a belt tension measuring tool (but I'm going to get one), and I definitely don't have a fancy laser guided pulley wheel alignment tool. I discovered that the puller/pusher I rented could fit on the pump without removing it. I used the OEM Tools Pulley Puller/Installer from AutoZone. I loosened the back two bolts and the top pivot-bolt — keeping them just barely loose enough so that the tensioner could be adjusted. I started with the pulley as far back toward the pump/firewall as I felt comfortable (there was maybe a quarter inch or less of the pump's shaft visible between the pump and the back side of the pulley). I'd fire it up, see what it sounded like, and mess with the tension a bit — either tighter or looser. Then I'd shut it off and scoot the pulley wheel forward in tiny increments until I finally got to a spot where it wasn't making the offending noise when idling. What I'll Try Next: I was thinking about trying a deep clean of the belt and pulleys and some belt conditioner spray. But I might just deep clean the pulleys and get a brand new belt and then hit it with some belt conditioner. Thanks for the tip. That makes sense! -
That’s an interesting suggestion, @Eagle_SX4! I might give that a try this evening. Although, I don’t think I’d be able to replicate the tension… @eaglescout526, I just changed the pump last weekend. Pump is brand new, pulley wheel is the same and belt is a year old. The clicking is kind of rhythmic. It happens at regular intervals. I need to do some more process of elimination for sure. -
I ran the power steering the way it was -- with the clicking -- for about a year. I think the most I've driven the truck in one sitting is about 50 miles at a time. I've probably put 500 miles on it or so. I don't know if that's enough to destroy a belt that's catastrophically misaligned, but I would think so. What I'm saying is that I don't think it is terribly, terribly misaligned. But this is the path I've been chasing to resolve the click. You know... with everything I've learned so far about this truck, I wouldn't be surprised if the culprit ended up being something else or something bone simple. But it's all interesting! It's a journey, you know? -
That’s great, @eaglescout526! Exactly the kind of thing I was looking for. I did NOT realize the alternator pulley has an extra groove. Maybe it’s not critical, but that helps me picture what might be going on. I’m looking forward to seeing your alt pulley so I can compare. -
OK… before I go any further. @eaglescout526, are you saying that the issue with these pulley wheels is that it is difficult to press them on far enough? Because based on the way my belt was sitting, I thought I had originally pressed it on too far. So I started backing the pulley wheel off a bit. I did not try going deeper, and I could have gone a bit deeper. Also, @eaglescout526 Thanks, and please do show me what you have. @GonzoTheGreat I do need to get a stethoscope. Keep forgetting to do that. But I am 95% sure it has to do with the power steering. It clicks when it is simply running. I don’t think turning makes much of a difference. But the clicks get more rapid with acceleration. Honestly, it’s like the pulley wheel isn’t quite true or something. Like every rotation there is one spot that catches a little bit. THINGS I STILL NEED TO TRY: 1) Use stethoscope. And/or remove PS entirely, reconnect old flywheel. See if sound persists. 2) Try new belt. I should be able to do 1 & 2 this weekend. 3) See if I can get exact part for PS pulley wheel. 3.5) If I can’t get exact part, source a cleaner pulley wheel smoother grooves. Or… do a better job smoothing it out. Not sure when I can get to these steps. QUESTIONS I STILL HAVE FOR COMMUNITY: A) What is it about the exact power steering pulley wheel part that makes it so critical or at least desirable in the 2.5L engines from the late 80s? B) Eagle Scout noted that there is a specific alternator pulley wheel for 2.5L without AC. He said it “sinks in.” I take it that means toward the cab? If that’s the case, I may have made a mistake when adjusting the pulley wheel, because I was worried it was already too far back. P.S. - Sorry, as always, for the super long posts. :-/ -
Hey @eaglescout526! I thought I might hear from you. Still no AC. One of these days, I swear… I’ve got most of the components now. I’m attaching a pic of my alternator pulley. Belt is off currently because I wanted to get a good look at my PS pulley. -
UPDATE: My power steering pump is still noisy, but now it only makes noise when the engine is cold. Once it gets warm the noise mostly goes away. I still want to get to the point where it doesn't make any annoying clicks or chirps, but patience is a virtue and all that. I fixed it by going real slow and experimenting with different belt tightness and pushing the pulley wheel forward and back by millimeters at a time, until I found a spot that was pretty good. --- --- --- ORIGINAL POST: Sorry to post a new thread on this so soon , but I wanted to try to get a conversation going about the power steering pulley wheel on late-80s Comanches with 2.5L engines. My issue is minor but annoying. The power steering pump works, but it makes noise, specifically a clicking noise. I did a bunch of reading last night — including of old parts manuals. It seems like the 1987-1990 and possibly 1991 MJ, XJ and SJ’s with the 2.5L and power steering, came with a pulley wheel that is hard to find these days. The part number is 5300 3805 for those who are interested. I have some questions about this, and if we can answer them all in one thread, it could be really helpful to anyone troubleshooting their power steering on an ‘87-‘90 (and maybe ‘91) MJ, or other similar jeep with a 2.5L + power steering. QUESTIONS: 1) Does anyone know why other similar pulleys cause issues on the ‘87 and other adjacent years with the 2.5L? And before you answer, I understand that they don’t line up quite right. But does anyone have details or theories about how/why they don’t line up? Are they too far forward? Too far back? Is the angle off? Are the ribs on the pulley not quite right? All of the above? 2) If someone like me can’t find the exact OEM part or parts, has anyone had luck with making other parts fit? What did you do? Did you put spacers behind the bracket, for example? 3) In my case specifically, the pulley wheel I am currently using is marked G3 53002909. I think it came off a YJ, but maybe something else… with this particular pulley wheel, is there something I can do to fix my issue (which is a clicking sound)? DETAILS & PICS: - Pump Style: I have this style of pump. It’s the kind with a remote reservoir. - Belt Position on Pulley: Here is how the belt sits on the pulley. I tried scooting the wheel forward on the wheel, but it didn’t make a difference. Probably because the grooves hold it in place. - Rough Grooves: I was originally thinking that the rough spots on my pulley wheel’s grooves were playing a part in this. And maybe they are. I tried my best to file/sand them smooth. Before: After:
Clicking Power Steering Pump, Belt, Pulley, or...?
Well... Now I'm reading up on this a bit more and I'm seeing lots of posts that say the pulley for the 2.5L is hard to find. Anyone know anything about that? -
After doing a bit more research, I'm thinking that what I might want is to get some ZJ springs for the front end, do a little bit of spacing on the front and the back and call it a day. I'm not trying to build a crawler. As I mentioned, this is largely an aesthetic thing if I'm being honest. Snooping around the forum I saw someone mention that just doing a little lift in the front really balances out the look of the truck. I have the 2.5L. Do you all think that doing the ZJ V8 spring swap would get me what I'm looking for there?
Hey @ghetdjc320! Maybe I just haven’t been paying attention, but is the KJ rear axle a common mod? I’m sure you chose the axle for more reason than just looks. Why’d you go with the KJ rear axle?
Hey all! Before I go through the trouble of pulling my power steering pump again, I wanted to consult the community. I've got a clicking sound that seems to be related to the belt, a pulley wheel, or something like that. I am fairly sure that I've isolated this issue. I'm 90-ish% sure it is something related to the power steering pump. So, over this past weekend, I replaced my pump. The symptoms seem to have improved, but it's not fixed. I don't want to drive the truck too much until I get this fixed, because I'm worried that this is an issue that will get worse over time. The Issue: Clicking Noise Speeds Up & Slows Down w/ RPM I first noticed this shortly after I had power steering installed. I would post a video, but I bet the moment I pull out my camera, it won't make the sound. Plus I find that engine noises don't translate that well over phone cameras. Essentially, it is a click. I don't think it's a chirp, although it's kinda like a chirp. But let's call it a click. And it speeds up or slows down with engine speed. What I've Done So Far - I've done the water/soap test. That seems to make the noise go away. - I've run the engine without the belt hooked up: No clicking noise. - I've replaced the pump (just the pump... not the gearbox). I did this because after I took the belt off, I observed that the pulley seemed to wobble a bit. Kinda like the pulley shaft was loose or not fitting right into the pump housing. I figured it might be a bad bearing. I thought about just replacing the bearing, but that seemed like a ton of work and I realized it could have been a busted vane or something else, so I just replaced the entire pump. What I Haven't Done I have not tried to run the belt without the Power Steering Pump connected. That would involve reinstalling the old flywheel that was in pump's place. I may try to do so next weekend. I have not tried to install a new belt or treat the belt with some kind of product. I have not tried a new pulley wheel (I think this my next step). The current pulley wheel is kinda beat up. My Questions Anyone Experience This? If so, were you able to fix it? Pulley Wheel Recommendations? I see a lot of different pulley wheels at a lot of different price points. Belt Tension: How much do I need to obsess over belt tension? Got recommendations for a quality belt tension measuring tool that won't break the bank? I've just been doing belt tension by the Goldilocks Method. Not too stiff not to loose. But maybe I need to step up my game. Pulley Alignment: How much do I need to obsess over pulley wheel alignment? My current theory is that the clicking has something to do with the pulley wheel itself. It's kind of beat up and has a few chips in the grooves. I also thought that maybe I need to be more obsessive over the alignment of the pulley wheels. I know that there are laser pulley wheel alignment tools but the ones I've seen so far are expensive! If I can rent one, I would be willing to do that to get the alignment perfect. Better Power Steering Pumps: I'm currently running a TruGrade pump #7081. I think that is what was in there previously, as well. It seems like there were two types of pumps that Jeep used originally. One was the "Ham Shaped" one. That is not the one I have. Picture of my pump is below. Maybe I need to get a different type of pump? This is the pump I'm currently running. Napa Auto Parts says this is the only one that fits my vehicle. There are other types of PS pumps (but maybe they are for the 4.0, and I have the 2.5). This is the other style of pump:
And @89 MJ that’s good to know. If I put equal spacing on front and back does that solve for what you are describing?
Thanks to all who have replied. For some reason I didn’t realize that the back wheel base was actually narrower. I guess I thought I was something of an optical illusion. D’oh! At any rate, I was thinking I’d put spacers on front and back. Appreciate the pics so far! Anyone else got what I’m looking for? @fiatslug87, do you have any other angles, like from the front?
Wire Over Driver's Shoulder Above Seatbelt?
I missed your reply, @watchamakalit. Sorry about that. Maybe I will eventually. I have been on another streak with electrical work recently. And I’ve been starting to add some switches to the dash. Just this week I added a new LED light to my camper shell and hardwired it with a switch in the cab to turn it on and off. Good for checking on the dog and other precious cargo when it’s dark outside. I’m planning to add a three-way switch function eventually. But doing that will require either a second dedicated power line to the bed, a complex relay system, or an RF relay. I really need to start a build thread. I promise I will eventually.
