Everything posted by Skylynx
Though looking at it… i’s mot sure i can see a limited slip dif in there? Maybe the dude just slapped the tag onto it and it’s calling it that? Hahah am i wrong though? Is that a limited slip in the picture? Cause as far as i know it’s an open one.
Project “Tomahawk”
Skylynx replied to ghetdjc320's topic in MJ Hardcore Tech: Epic Journeys to Greatness
Man, those rear window louvers look dope… did they ever produced them at all? I don’t think i’ve ever seen em -
Wow! La linda oaxaca! Tengo mucho que no voy para aya… si algun dia estas de regreso y pasas por Monterrey, let me know! I’ve been looking around and i found something interesting in the marketplace, some dude selling a Limiter slip rear dana 44 that apparently came out of an XJ, looks well maintained and the want 350 USD for it… it’s got drums still and i’d like to eventually switch to discs. it’s still stock with the 3.54 gears, though i’m fine with that until i start doing the 4x4 conversion. another downside is that they’re about 500 miles away from me… so..yeah. is this a good option? Should i even consider it? Here’s a few pictures that they sent, it appears to have all the break lines on it, donno if I’ll be able to use them, but they’re there.
Good to know! It looks beat and rotten in some areas, particularly on the other end so i am gonna end up switching it, i already ordered a plate and fin trans cooler and a new radiator as well, the current one has been repaired many times and doesn’t seal well anyways, plus it’s likely filled with gunk at this point. hopefully those two help keep the truck happy!
Yeah, from what i gather it’d be best to do as you said, an HP in the front and an LP on the back, i tried talking to this guy to moderate his prices but he doesn’t want to come down a single cent.. also, he changed his mind and will no longer sell the rear axle alone, he now sells them both or nothing for 600 bucks, so i guess the deal’s off. I’ll keep an eye out for a cherokee dana 44, or a comanche one even though they ought to be unicorns i bet.. i’ll try to upgrade the rear axle for now and worry about the front one later once i have the whole 4x4 pieces ready to go. you said you lived in mexico for a while though! Where did you live?
Ok, this is all great info so first off, thank you for posting this! <3 I did imagine the axles originally came with low gears but since they seem to have been previously modified in the past, there's no telling what they have in them now, they look pretty wheeled and used in person, much more so than in the pictures, i've been told. I think both of these axles are low pinion though, not just the front one, i'm not too well versed in axles to confirm that but the seller said that they are both low pinion. When you say that for $600 for both axles is "a rip" you mean it's a ripoff? so it's not worth it to buy them for that price? or the opposite? sorry if this is a dumb question, English is a second tongue for me and i'm not entirely proficient as i'd like to be with it yet. is adding unsprung weight a good thing or a bad thing? i did knew that the HP dana 30 was pretty much the same as the waggy LP d44 front, but i THINK the d30 still uses c-clips? which i've heard it's a big point of failure. I have heard before that the ford D44 axles are good but i have no idea what kind of ford truck i should be lucking under for them, though i'd like to find an axle that matches the size of the comanche's, i'd buy a Ford 8.8 and be done with it if the Dif weren't at an angle under a jeep and you need spacers to make the wheels fit cause it's smaller than a jeep axle. If the ford d44 is the same size as the one you'd find under a jeep, but is HP and specially if it already comes with disc breaks i'd look for that thing until the end of the world! a dana 44 like that on the back and a good, well built D30 in the front is all i need, honestly, i'm not wheeling this thing over boulders, it's more of an overlander build, i doubt i'll put more than 4 inches of lift on it, and won't go over 33's or maaaaaybre 34's Still, 600 bucks is Steep as hell for me right now, and it'll be a while for me to put those axles to use since i don't even have a transfer case yet, if i could get just a rear D 44 to replace the D35 under the bed of my manche (which is about to fail and i don't want to invest in repairing at all) so that i could at least drive it for now and not feel like i'm sinking money into something I'm getting rid off anyway.. that would be ideal. i can worry about a front HP dana 30 or a 44 when i have a transfer case for it later down the road when my wallet has had some time to heal up... what would you recommend in this case? what trucks should i start checking under? even if they don't have disc breaks to start i'm sure i could convert them, i just need it to be the same length, or not as drastically different as the ford 8.8 is... i can go to some junkyards and start looking under trucks as soon as tomorrow for a good rear D44 axle that'll fit under my jeep, i'm not expecting a bolt in axle by any means, i know i'll have to pull geometry on it regardless, just want a good option.... chances are the man at the junkyard will sell it cheap to me, way cheaper than what this guy is trying to get out of me for some mystery LP D44's
Yeah... i noticed that way too late sadly, but with the right tools, attitude and a few burnt brain cells i made it work! i need to replace the whole AC system anyways, the hoses are cracked, the compressor is toast and the AC condenser is no longer in the truck at all, so might as well go with the newer models for the AC now since i already have the toughest piece to change out by far in the truck, and it's the one with the more aftermarket available for it.
Awesome! i'ts good to know where this puppy was sold, and that the tailgate it's got is actually the original! very happy with that. Little curious about this though! NHB HVY.DTY/AUX TRANS OIL COOLER The truck has a small tranny cooler in front of the radiator that i'm planning on replacing, but it honestly looked aftermarket, could it possibly be OEM? This is the one that i mean, you can kinda see it back there lurking in the shadows!
@89 MJ Supposedly they are! and thanks for the heads up, i'll be sending them a message! Sadly, i talked to the guy again today and he told me that he made a mistake with the price yesterday, 300 Bucks was just for the rear axle, he wants 600 for both of them now, making this deal a whole lot less enticing and possible for me...
Speaking on undecided possible purchases in which one seeks to be better informed and is cautious in the way he'd spend his money into a jeep... yeah we're done playing that ahah! my Comanche, like many others here came from the factory (i think) with the optional 3 piece sliding window on the back it's a very nice option to have, specially in the summer days when you can open the whole truck up and have the air flowing through and all over! sadly, again like many Comanches here in this forum, the sliding window in mine was gone, lost to the many eons this truck has seen, probably gone since before it ever entered mexico, in it's place it's got a little, non-tinted, non-tempered, non-curved piece of 6mm glass covering the hole, the latch is also gone, of course I can't wait to get rid of this thing in violent ways. But this week was filled with joy and bliss when i found a listing in a junkyard for a whole back window, the entire thing! for just 50 bucks! i paid immediately! The three glass pieces, the middle slider window and even the original latch! the only problem is that, well.. this junkyard is in Kentucky... and i'm in mexico... 2,300 KM (1,450 Miles) away... with the border closed due to the Kung flu still... BUT! i have a friend that lives in Kentucky, and he made the one hour trip over to pick it up for me and is going to send it over to me soon! wit me paying shipping of course, i asked him to take some pictures of it and this is what he came back at me with, i can't tell you guys how excited i am for this to get here, it's going t look so damn good in the Comanche once it's on and complete! he told me that the guy in the junkyard said that this gem has been sitting there in the sun for 17 years and nobody ever got interested in it, so he listed it online and i snagged it in just under a few hours of him posting it, he felt robbed haha! i can't believe my luck, honestly! Apparently this small bend on the metal is the only damage on it, and was caused when bubbah pulled it from the truck with a crowbar... i can't be happier with this reckless purchase, i hope it gets here safe and sound! Continued!...
This... pretty much catches up to today, i'll be looking out for electric issues threads and try to start piecing things together from there i guess, i really don't know much of what i'm doing with all this wires, i may post some of that in here too actually, and i'm already trying to convince a friend of mine who works with this stuff to at least tell me how to do things, i really don't want to be unsafe or cause a potential fire hazard or fry some of the components, until i'm sure of what i'm doing and how to do it i won't cut a single cable on that harness, though i may further remove it just to see the full extent of the damage. In other more Caveman brain level news! Axles!! i found a guy locally with a pair of what he claims are a pair of Dana 44 Axles that he pilled from under a Wagoneer, for which i have some doubts, he has no idea what gear ratio is in them at all, and they seem to need a rebuild desperately anyway.. the front axle at least seems to have some custom shock mounts on it, which leads me to believe that they may not be stock gears in the inside since they seem to have been worked on and modified in the past, that being said they don't appear to be bent or cracked, and no pitting either or major rust on them. He wants 300 bucks for the pair of front and back dana 44's in the state they're at, rear has drums and buying this axles would mean that i would either have to switch the shafts on them to 5 lugs or sell all my wheels and replace them with 6 lugs, which only increases the price and hassle of the whole ordeal... is it even worth it? this are the only pictures he sent me, i may get more this week if i make the trip to go look at them i really need advice on this one, 300 bucks is quite a lot of money here in Mexico i'd have to save up for it since i don't have the money right now, and still then i'd have two beaten axles, useless until i sink more money into them to rebuild them. i really don't know what to do with this one guys, and i would seriously appreciate any advice from you on it. Here you can see what i mean with them being worked on in the past, this block here doesn't look stock, right?... should i be worried they're not virgin anymore? haha! If you have any info on this axles, what it takes to adapt them to the Comanche, if they're even a good option for it, or ANYTHING ABOUT THEM! Then please let me know, i'm eager to find more relevant info on these from the eyes of the Comanche connoisseurs i know lurk around here! Continued!...
@ghetdjc320 Hah! yeah, sorry i get carried away with storytelling sometimes, hope you enjoy the posts though! i'll be honest with you, i don't even know what the evap core probe is, what it's for or where it goes, so thanks for letting me know it even exists haha! i'll do some research for it even if fixing the AC system is not a priority right now, mainly focusing on making sure all the work i need to do inside and under the dash is done before i put it back on so i don't have to take it all back off for that one single thing, you know? so making sure the HVAC box and controls are complete and working, along with fixing the wiring harness and possibly even making the necessary preparations for the future radio, speakers, powered locks, windows and mirrors and maybe a few 12 V outlets for cellphone charging! along with all the other switches, lighter, lights and stock things like that of course it's gonna be tuff with me not knowing ANYTHING about electricity or wiring, but i'll mannage! (?) HOEPFULLY
so, here's the Brake booster, it looks bad but i have absolutely no idea on how to diagnose any of this things, still, i heard that the double diaphragm ones from later models are way better, so i'll try to get one of those soon! hopefully the breaking problem is about this thing and switching it over for a newer model helps fix things.. this is the charcoal canister as i removed it from the truck, it was absolutely caked in a layer of burnt grease and motor oil, it was even inside the plastic holes that are meant to have the vacuum lines in letting me know this thing has probably not been in use since it entered mexico, i'm not sure i'll use it again even though i cleaned it well and it's apparently in working order, i blew into it and there's airflow... i'm unsure it's even matter to have it and create another potential failure point or to ditch it and forget about it, Mexico deosn't control for emissions what so ever so, maybe?... i don't know, hopefully you guys will let me know what you think! before cleaning, straight out of the truck, aaaaand... Cleaned! again, it appears to be working but i'm not sure if i'll re-use it or ditch it, looking forward to your comments! Once this was done i turned my attention over to the rusty Parking break inside the cab, i loosened the nut under the truck bed to be able to remove the cable and take the parking break tensioner which was rusty as heck Here's a before picture of it, it creaked and dragged when actioned, to i took it out, carefully cleaned it, used the drill's wire wheel to remove as much rust as i could after i dismantled it as fat as i could, removing the sensor and the springs from it, then i used masking tape to cover the plate with teeth as to not to paint that, and then gave it the good old rustoleoun treatment. it looks so much better now that i put new grease and removed the rust from it, very happy with how this turned out, i didn't do the springs cause i don't know how the paint i have would react to being moved like it is, and would rather first investigate before i frick it up. next morning i got a package in the mail, it was something i was eager to get because i've done this job before with my friend's car and i kind of liked it! plus it was just after the paint in the floor pans had dried up and was now walkable so i could work on the inside of it with no fear of messing up the previous work i've done repairing the floor. Sound insulation! apparently this thing helps with temperature regulation too? not sure about that though it would be nice! i'm mainly adding it to have an even more quiet ride that me and passenger can enjoy, also boosting the music once i get a sound system in here! The roller that i ordered to help me apply this thing broke apart in the first three rolls though, and i was not about to wait for another one to arrive, so i made my own tool to help me apply this thing.. it's just a copper tube i flattened 6 inches of in the anvil with the hammer, then folded it onto itself for more support, it was still kinda flimsy so i drilled a couple of holes from the tip that was floppy and into the tube, making it look like a Muppet with big eyes, but holding the whole piece together well! He can see you too! As you can see, it's rounded and i made sure to file all the sharp edges that could cut the insulation up, it's also decently sturdy so all i had to do was press it onto the aluminium side of the insulation and drag it across it with some pressure, flattening it onto the surface of the metal and adhering it permanently to muffle the noise of the naked sheet-metal. i did the roof and the back wall, waiting on doing the firewall and the transmission tunnel until I'm done working inside and i have at least a bit of an idea of how to tackle the wiring harness problem... Continued!...
Let's start from left to right, by this point the left side of the engine bay is pretty much entirely empty, the carbon filter thingy seems like it hadn't been used in decades, some other previous owner has already converted this truck from the closed to the open cooling system, though the reservoir was toast when i got it, so i'm getting a newer one for it, i still have the plate that holds the older style to the side and may use it for something else, the battery tray is entirely broken, unusable and trashed, the AC motor thingy is just there as a pulley right now, the hoses were all unplugged when i got it already, and the condenser that should be in the front of the radiator is nowhere to be seen. Literally the only thing remaining from the Battery tray, i'm tempted to re-construct another more sturdy one with the scrap metal that i have, would serve as welding practice i thing. tHE STUDS THAT HOLD IT SEEMS TO BE IN PLACE THOUGH, AND NOT RUSTED, SO AT LEAST HAT'S GOOD! Just after typing that i realized i was in all caps. i won't delete it i won't apologize either. this tiny, rotten thing was the only thing left from the old vacuum system along with a few other lines, things were desperate, but i bought a new Drop-in system and plugged in where it needed to be plugged in, i followed youtube videos for this, i have not tried it yet because the truck won't turn on without a battery, but everything plugged in well and seems to be in working order. Here's the absolute mess i'm dealing with here, i know, it's giving me nightmares too.. Continued!...
Given i was already down here, waging an unrelenting war against rust and slowly winning it, i decided to attack the one other rusty thing that was very clearly in sight, but my laziness was still unsure about removing it or not,i'm sure this next step was completely unnesecary, and that it would have been fine if i hadn't done it at all, but i did it anyway because i had the time, and honestly just looking at the hot mess of wires scared me away from even trying to diagnose and fix them, since i know very little about electricity, and i'm still reading upon how to.. even start fixing this. Anyway, i took the break pedal holder out which was easy now that the dash and everything else was out of the way, just four bolts to the back, two on the front and one to the break pedal and the booster held it in place, here it it before i removed it, in all of it's surface rusty glory. I made sure to mark and check on all the sensors before i removed them too, taking lots of pictures from all angles this time. As i said, it's all just dirt, grime and surface rust, but if i already had access to it like this, why not coat it in paint too before forgetting about it forever? to the right of this picture too you can see the ECU holding plate before i painted it, but after i wire-wheeled the surface rust away, most of it anyways. I took the holder out and wire-wheeled it down hard until it was silver and shiny, then hung it outside and blasted a few layers of rustoleum over it until it was nice and covered, this thing will hopefully never have that rust on it again, i did the same with the break pedal and the accelerator one too, making sure to cover the cilinder with masking tape as to not get any paint inside it that could clog it up, here's a picture of the finished holder, but i don't appear to have one of the finished pedals for you guys this time, maybe later eh? It was at this time, as i gave the last sprays of paint to this thing that i got a call from my buddy, the one i gave the truck at the start of this and that he supposedly fixed the breaks, he did.. for about 6 or 7 pumps before they failed again, we knew the truck had a major vacuum leak, but he had been thinking about how the breaks failed again and he told me that it may be the break booster being bad, and that i should consider on switching it, i've read somewhere that there's better break booster to the one i have, i think they come from later model XJ's or a WJ too, i may go have a run at the junkyard to see if i can snipe one of those, in the meantime and while this dried, i moved over under the hood to try and see if i could help the Vacuum issue at all.. there's... many reasons why i haven't shown the engine bay of this thing yet, it's NOT in bad shape... no visible rust from what i can tell, and it ran decently-okay-ish when i drove it here despite the exhaust and vacuum leak, but it's really ugly.. i have big plans for this engine bay still so don't worry, she'll be looking much better soon hopefully! There's.. a lot to cover here, so let's start out journey from left to right and see what's going on... on the next post cause this one's already decently long! Continued!...
I've seen a lot of rust in this trucks over the years, rocker panels, floorboards and wheel wells being the main culprits of this natural process that oxygen and iron undergo and that water catalyzes, but never have i heard of any jeep having rust in this spot i found on mine, and maybe it's be a good idea for you to check your jeep just to make sure yours doesn't have it too. This is the three holes going out into the engine bay right over where the wiring harness goes through too, one is for the hood latch and another for something else i can't remember, but right over those, right in the very corner i had a small rusted through spot that i had no idea how it got there, the source of this rust still eludes me to this day and frustrates me massively, just when i thought i was done welding sheet metal i had to go and do it yet again, i grabbed the welder back from the cabinet and began tracing things. First i grabbed the dremel once i had wire-wheeled the whole area with a drill because the angle grinder had absolutely 0 chance of reaching this spot... luckily from the three walls that intersected in this corner only the firewall appeared to be affected by rust which was good news, the dremel with the cutting wheel was a big help to actually get this rust cut out, even then i had to over-cut in some areas due to the lack of space i had in such a difficult spot, here you can see the cuts i made as a magnet holds a piece of steel i found in my scrap that nearly matched the hole, but in the end i decided not to use it because it left open a few major gaps, and instead i cut one out from a larger piece to fit it in better. Here't the final product, welded in place and painted well from both sides. The other problematic part was the ECU's mounting plate on the top of the firewall next to the steering wheel, for some reason there was some surface rust creeping out from under it, but thankfully it all got eliminated when the wire wheel made a pass over it, still, i had to find the source and i knew that right over that was the electric motor that controls the windshield wipers, i got out of the truck and removed the trim panel that covered it, before struggling with the motor for half an hour before i cohered it enough to come out. Again, the dust was everywhere, so i cleaned as much of it as i could as i went along, this is just under the panel covering the wiper motor Here's the Wiper motor coming out, after removing the 10 mil bolt i find it's easier to push it down so the wiper studs come free from the car, then pull it towards the driver's side while rotating it upside down and then pulling it out that way as you see in this picture, i'll try to do the same process once re-installing it and let you guys know. after the motor was out of the way and i gave the inside of the "nook" it was sitting in a quick wipe and clean it was pretty clear where the moisture was getting in through, in this next picture you can see the ECU mount's spot welds from up top, they're bent and twisted and one of them split recently i think, because light barely shines through it if you hold a flashlight inside the cab towards the mount, so that's the source of that leak, i'll be sealing it with sealing puddy and silicone, as well as many coats of paint from both sides since i don't feel like welding this, at all, in this two pics you can see the same spot from inside and outside, already with the first coat of paint. the ECU mounting plate, and... the shoddy spot welds under the wiper motor, you can see the right-most one being the one that broke off and allowed water to leak into the cab. Another problematic area was just behind the break pedal, apparently the troglodyte that owned this truck before me thought it would be a good idea to drill a hole through the firewall under the pedal and into the wheel well for absolutely no reason at all and leave it as such, in this picture you can see it cleaned, welded and sealed already, but originally it was surrounded by zilt and stuck mud that ran all the way down to one of the rust points in this side of the driver side that i had previously fixed, i wouldn't be surprised if the whole diver side damage was caused by this idiocy alone, so i'm gald i decided to remove the foam insulation for now because this was pretty well hidden because of it and i wouldn't have caught it before it kept damaging things out. I made sure to leave a FAT weld on this bad boy, plugged it well and nice before baking it in undercoating on the outside and bed-liner on the inside. Continued!...
Finally back updating this thing! SO, again i don't have many pictures of me fabricating the floor panel from a flat piece of sheet-metal, [or any at all for that matter] But i do have a picture ofit being welded in after it was made, where you can see the details i had to do, or at least tried to, i started by tracing the hole onto a piece of paper and then using that as a template to cut the piece of metal i was gonna use to patch the hole, leaving about a CM on each side wide-wise because i knew the bends and angles i'd have to form into it would eat up some of that length, and leave me with a piece that's too thin if i didin't add more material there. I wanted the piece to be more structurally sound than just a flat piece of steel, so i tried my best to give it the same strengthening bends the original piece had by using an anvil and a sheet-metal hammer, granted, my best is not the best out there, so it came out... not pretty, but functional, and since this'll be covered by the carpet and insulation, i wasn't bothered by looks. This is a picture of the moment when i did the last welds on this piece, i was sweaty and tired cause it took nearly all day to complete with the welder i purchased but in the end i was happy with the result! The welding job is again, my best, but not the best out there, i'm still learning how to weld better since this is the first times i've ever done it seriously, and i was forced to use the welder with flux core wire which is a lot more sparkly and spotty than MIG wire, i was originally going to use MIG, but my friend who was going to borrow me the gas cans for the job so i didn't have to outright buy them was busy with them at the moment, and i was forced to use flux core instead since i had no shielding gas, the welder i got also gas the Option for MMA sticks and apparently TIG too, so maybe i'll use those later when i'm building the bumpers for this thing. Here's a better look of the welds and the piece i fabricated, as i said... yeah you get it, i'm no pro, but for now it serves the purpose! i covered the whole bare metal area with a can of rust preventing Rustoleoum paint, and then came back 2 days later and sprayed a few coats of truck bed-liner over that just to give the paint that much more protection, for the underside i used undercoating, also from rustoleoum, still just stuff out of a can, but for now it'll hold up fine, i plan on undercoating the whole underside at some point in time, perhaps when i make the switch from 2x4 to 4x4, or maybe if i go from renix to HO, still not sure if i'll dot hat though, we'll see. I did the same with both sides, making sure not to leave any area without coverage from the new paint since i had to wire wheel a fair bit back to remove surface rust that was starting in some other areas, thankfully nothing deep or compromising, so i am glad i caught it in time. This is the driver side after the first coat of paint... Aaaand the passenger side too. quick note before apinting at all, cover the studs that hold the seat in place with masking tape,you don't want excess paint, let alone bedliner messing up your threads! After this was done, dry and sealed i began focusing on the electrical systems, i knew the harness was pretty damn HECKED .... so i started to try and get everything more or less organized so that i could at the very least know what the hell i was doing, it quickly downed on me that the rubber and foam insulation matt on the firewall was getting in the way a lot and it'd be easier to just remove it, it was also extremely dirty too, and would need a wash, and it'd be good to see the condition of the firewall from this side too, so i got onto it and began removing it slowly until i managed to peel it off the glue pads on the wall and the cables hugging it from all around until finally it came off with a cloud of dust, this thing was nasty as hell. trust me, this picture does not do it justice, it was entirely covered in engine oil and dust, i rinsed it many times over in a big bucket of water and at the end of it i had a bucket of mud, it was a good call to pull this thing off just to clean it, but also because it revealed some other problems under it that i'm glad i caught before they went ballistic. with rust of course! Continued!...
Holes are good.. holes are valid, it's okay to have HOLES. holes help us get one thing from some place to somewhere else without ENTIRELY removing what's in between, Some holes are BIG and some are small, But in the end a hole is a hole and it will do hole things... or so my friend's say. a lot of things have holes... morals, ideologies and logic, specially if you're a politician! even the universe has black holes, though i have no clue what race has to do with that. Even people like you and me have holes! lots of them with all sorts of functions and fun activities that are not to be delved into right now. Cars have holes too! and jeeps are cars, so it's okay for your jeep to have holes! That being said, moderation is key, and TOO MANY HOLES can be a bad thing too! such is the case for this comanche, she got carried away a little, got too excited and went on and done did actually got gotted some dem darn rust holes on er'... which is SAD and LAME but nothing that can't be fixed...i wanted an excuse to buy a welding machine and learn how to weld anyway! Don't worry,i ditched the battery drill for the angle grinder with the wire wheel right after this picture, but you can see the major holes this thing developed in it's career, though as i said before this jeep was in pristine condition compared to others i saw before buying this one, or jeeps i've seen in this forum before, hey, for the price i got her, this is nothing!... so i thought. Pretty intimidating, yeah... but i was thorough with the angle grinder until i had almost the whole footwell shining silver before i got the wire wheel out and cut out the problematic area, though before i did that i did go over to the driver side where there was a few patches of surface rust that looked like they were starting to be a bit pitty... i hoped once the wire wheel went over them they would clear and not poke through, but i wasn't that lucky, thankfully the holes on the other side were minimal, small patches i could so easily, unlike the big, major one on the passenger side. Here you can see the whole passenger side cleaned the hole on the underside and the top side where one panel meets another is pretty evident, this is also around the time when i realized what was likely causing this rust to appear, the rubber garmet that plugs the hole going through the wall to the right side and up to the anteena was not where it was supposed to be, letting the tire throw rocks, dirt and mud straight into the cab through it, with where that upper hole was i took like 4 fistfuls of dirt out from under the carpet where it had accumulated moisture and dirt for years. This is the driver;s side, as i said, no major holes were visible, or any holes at all, sadly as soon as the wire wheel was used to remove the pitting rust some small holes appeared and i had to make some repairs, 5 or 6 patches of different sizes were used, but nothing major. Here's the immediate after on the driver's side once some of the holes were patched, with 3 more remaining all the way ontop which i later patched too. Aaaaand this is the passenger's side once the whole problem area was cut out, i then traced this to a piece of paper and then translated that to a flat sheet of 16 gauge metal to make my cuts, giving it 1 CM of tolerance on the sides cause i knew i would need to bend and twist it to fit well, and that would reduce the actual size of the piece I'll continue updating this tomorrow, it's late at night and i'm tired, but we're half way caught up til how things are right now, so the battle's already half won! more updates then!
SO me and my dremel had a good talk with that lid, we told it that it should REALLY consider switching directions or not change at all, it refused entirely, so me and my dremel had to get a little bit handsy and creative, First thing i did was to grab the lid and peel off the Auto-adhesive foam cover it had enough for me to make the cut with the cutoff wheel without messing it up entirely, here in this picture you can see the foam insulation i'm talking about, it lines the entirety of the inside of the Lid, you can see square imprint on it from where the old, rusty EVAP sat against it I then cut a semi-symetrical piece of the plastic that you'll see here in another picture, flipped it upside down so that the former inside of the box was now the outside, reversing the down turn angle the lid was taking and preventing the EVAP from fitting in the box, NOTICE that i made sure not to cut the edges of the lid where the box would seal against it, only through the body of it so it would let the EVAP poke out from under it and let the new upwards angle i gave it seal it down into it, the piece of foam that i cut and peeled from the former bottom now was pasted and sat on the former top of the lid, keeping the insulation in the side it needed to be. View without the new lid on, as you can see i had to cut the exiting side of it, but i'd reconstruct that union later with rivets and spare plastic,along with gasket maker and the other products i already listed. i did the same with the rest of the lid, i had to cut the bottom tray i showed already to get the drain out of it so i could use that again to plug the hole under the box and route it out of the cabin with a rubber hose for drainage, i'll show how i did that in a few more posts., but i used parts of that too to seal off this new holes created in the new Lid and consolidate it as one again, keep in mind that if you're to do something similar to this you should try your best to always keep the rivets coming out and away from the evaporator, you don't want to have poky metal bits aiming at the radiator that could rub onto it and cause a leak, i made sure no rivet was close to it and so should you. From here on out the pictures sadly diminish a lot since i was so damn focused on just finishing the damn thing and not looking back, but if you want to i can get some more pictures of the finished product in the future and post them, it looks messy but i think i did a pretty good job converting this HVAC box into one that could accept this model of evaporator, though i would not ever undergo this again, i did it out of desperation and from the absolute bad luck i had finding one that was already made to fit this thing in the first place, heck i may go back and find one later and ditch this whole thing entirely if the opportunity comes, so do this at your own risk. another thing that i also did was put new foam on all the routing doors since the one they had turned to dust as soon as you touched it, i did that with regular foam, contact cement and an exacto blade, there's also a few metal pieces inside the box that i took out by drilling the rivets that held them in place, i attacked the rust spots they had with the wire weel (drill, not angle grinder, this pieces are super thin metal and would bend away with the power of the angle grinder., so use the drill) i sanded them until they were clean and shiny and free of rust, then painted them with black rustoleum again after a quick clean, settled them back in place with a few drops of gasket maker and new rivets in the same holes i drilled the old ones out, i did this with the "door frame" Pictured next as well as with the metal circle that sends air to the blower motor, along with all the shafts that connect the vacuum actuators to the doors, everywhere where i saw surface rust i attacked and painted over to stop it. you can see the rusty door frame behind my hand there, that's one of the metal pieces i took out and worked on, sadly no pictures from the finished product were found. SO The HVAC box was now sealed and ready to be installed again, but not before i tackled the BIGGER issue the truck had.... Continued!...
so, the reason why this New Evap wouldn't fit inside the old HVAC box was because of two things, the HVAC box had a taper downwards while the EVAP was consistently square, while also having a weird angle that honestly had no reason for existing other than to make my existence worse, here you can see a few pictures i took before i made the modifications, keep in mind, the Evap core Is 24 CM long, so in one side of the box i was JUST able to stick it in, while on the other side i had almost two CM of spare, in this unmodified configuration the Evap would go down and into the box just fine for the first 4 inches until the taper caught it and wouldn't let it go down much longer without permanently deforming the box or breaking it, and even if i managed to make it fit it was too tall so the lid on the HVAC wouldn't close on it, being almost one inch too tall for it to do so. As you can see on this side i had almost two CM of spare, good. But on the other side... It couldn't be closer, thankfully the Evap would fit in the space between the "L" the plastic made on the top left of the picture and the hole for the bold to hold the lid down onto the box, so far so good... two issues needed to be resolved next, first, i needed to eliminate that taper, make things straight enough for the evap to sit all the way down.. which leads us to the other issue, that tray you can see all the way at the bottom? yeah.. that's the other issue.. It simply had to go, it would fit the other (older model) of evaporator just fine, but it was absolutely getting in the way for this bigger one, that tray contained the drain for the condensation the evaporator was doomed to produce, and unless i wanted a flooded passenger foot well every time i turn'd it on i had to come up with something for that too. i decided to Bubba it up hard and break out the dremel with the cut-toff wheel.. yeah i was that guy, but to my favor this actually worked okay? spoiler alert by the way, haha! i made a few cuts down the side and under, but not at the top so that the plastic would bend out of the way as soon as the new Evap would start pushing onto the taper downwards that the box had, allowing it to reach all the way down to the bottom of it, at least that was the hopes..and guess what?.. IT WORKED!!!!!! Finally for once in my life i had made something worth that i could tell my grandkids over and over until i bore them to death, i was so damn happy!.. now to fix the NEW issue i created by making it fit, the massive hole on the bottom of the box.. I started to look around the piles of materials and junk i have at home from the construction jobs i sometimes do, searching for plastic pieces that will help me seal this thing in without issues, that coupled with the fact that i had a full box of rivets that i used to re-attach the metal parts to the dash made the job way easier. I found an Old paint tray made out from the same plastic as the box, which was also as thick as it was, i used the dremel on it to cut it to fit, made the rivet holes with the drill and a metal bit, placed Gasket maker where plastic would meet plastic to seal things off and then riveted the new piece in place, which gave me a permanent new shape and structural support for the rest of the patching up in needed to do, there was a lot of that still needed to be done. Here's a view for it from the isnide. This is the part where i wish i had taken more pictures of the process, but sadly i was so frustrated and hurried to finish that i just went full blitz onto this thing until it was done or i met a major roadblock, so you'll have to settle for descriptions, because i'm REALLY not opening that HVAC box again if i don't absolutely have to... from working with water for the last 15 years i knew for a fact that loose plastic pieces, gasket maker and rivets were not going to hold things for long, the rigid support they provided was necessary and good, but i also needed a more flexible support to unite that to keep things sealed with any and all shifts and movements the box is bound to have in it's life, i needed something to reinforce the it all, and fill the gaps in between the pieces while also holding them together like rebar does to reinforced concrete.. and i had just the thing in my tool closet. Honestly i have no idea what this mesh tape is called in english, and i'm not bothered to check, all i know is that we use it to fill the gaps in between drywall pannels and then spread drywall puddy over it to fill the seams while this mesh reinforces it and prevents it from crackling, it was really perfect for the job, it's made out of nylon and is also sticky on both sides, so i could place it in the HVAC box where i needed it, wrapped around the plastic pieces that would fill all the gaps and reinforce the strength of the gasket maker, and since it's made of nylon it'd never rot and give out, this thing will outlive me and my kid's kids. I only have one example in picture of it in use and it's this one, you can see it used in the far corner of the cut i showed you guys earlier. From that picture another problem was also pretty evident, i'd imagine, even with the tray removed the top cover would still not close down onto the EVAP, and here's why and how i went about to fix it.. There you can see the Evap inside the box while the Unadultered top covers it, still living a gap because it was just too tall for it to fit correctly, you can clearly see that from the left side of the picture, in the part where the heater core lives the top part of the Lid would easily and effortlessly cover the Evap if only it didn't angle downwards as it got into the Evap area, if it'd only stayed level instead of going down... yeah.. if only.. Continued!...
OOoh sweet! thanks! posting now
I couldn't think of anything other than the filth covering every single atom in and outside of this box, i'm not a squirmish person but this was truly horrible, it smelled like motor oil, antifreeze and sodomy, truly a sight of hell, and i decided to tackle that first, i took the heater core and AC evaporator out and grabbed the four pieces the Box divided into and hosed them down to remove the surface dust, but even the pressure washer could only get so much done, this next pic shows where the blower motor had been throwing dust at for decades, that stuff was so stuck into the plastic i had to use a Flathead and both hands to remove it in some areas, along with de-greaser of course. This is the side of the tray that laid next to that last pic, as a closeup of what i'm talking about. after 3 and a half hours i was left with the four pieces of the HVAC cleaned, i took pictures wherever i saw double-sided tape sticking onto the box, it seemed it once had foam on one side of it that has by now evaporated long ago, but i kept them for reference on where you should make sure to seal the box to prevent leaks and assure a good airflow, and i suggest you do the same if you also voluntarily undergo his hellish torment. Sadly things were just about to get worse from here on out, even if i was able to clean the pieces to acceptable levels and had the skills to put things back together okay, it wouldn't matter at all without new hardware, after all, the heater core was leaking, (because of course it was, duh.) and the AC evaporator was broken entirely, thankfully the Heater core remained the same for every year of the XJ and MJ, and finding an aftermarket replacement for it was a breeze! The same couldn't be said for the AC evaporator though... which would become a ghost that would haunt me for this entire HVAC restoration. This thing was toast, gone, Donzo! it only had one of the original two tubes, and it was clear someone had tried to fix it in the past in a desperate attempt to try and get out of the heat of the Mexican desert but to no avail, this thing's corpse would never work again, i did some research and the part number for this is apparently EV4177ATC, i searched far and wide for it but the only place i could find it was Rockauto for like 90 USD, plus they wanted another 60 for international shipping, and i knew this was just not going to be possible at all, plus reviews online said this worked best with R12 (now discontinued and increasingly more expensive) and even with R12 it was never any good at all... I searched elsewhere, anywhere for answers and ended up deciding to buy this: UAC EV4864999PFXC It's the AC Evap for a newer jeep XJ, i knew i was risking it cause i couldn't find measurements for it anywhere and i was not sure it'd fit in the HVAC box i had, but since reviews for it were good, it is adapted to be used in the newer, better AC systems, the fact that it's sister the heater core never switched sizes in the whole XJ/MJ production, and the fact that it was only 43 USD or so with free shipping... yeah, i took the risk Few days layer Papi jeff delivered the new Evap in a shiny, new Amazon box, i was nervous and eager to test fit it, so i took it out and rushed over to try and place it inside the HVAC box, there is where i realized that my gamble had not paid off, my cocky spending habits had gotten the best of me, i had two options from this point on, return the Evap and go for the original replacement with less efficiency and much higher prices, or go out and try to find a new Hvac box that actually fit this model, i did some research and saw that the early 90's Cherokees had the same dash as me, but a modified HVAC box that would fit a similar evaporator than the one i had now, so i grabbed my car keys and visited 6, yes. 6 junkyards in a day i expected the Junkyard gods would answer my prayers and show me the way, help me find the box i needed to put the Evap in and be done with it, but it was not to be, every Cherokee i checked had either the same box as me, or the one that would fit it was massively broken and unusable, i was trapped in the terrible financial decision i had made before, and would be forced to return the Evaporator and buy the expensive one... NO!! NOOOOOOOOOOOO!!!! NOT ONLY NO; HECK NO!!! I WAS GONNA MAKE THIS WORK, NOT ONE STEP BACK, NO SURRENDER!!! I got my @$$ back home and began thinking on ways to solve this, i read somewhere on the internet that the more wrinkles you have in your brain the more smartier you are, like for example Einstein had at least 4 wrinkles on each side of the brain while most normal dudes have at most two, so i started to fix that problem by banging my head on the wall so that my brain would much a little and wrinkle against my cranium for a little while, just enough time for me to come up with a solution to this massive problem... i did this for a while, i tore down two walls on my house and was still trying with the third, i almost managed to knock that one down too before the idea came to me.. eureka! it may be crazy enough to work, but i'd need measurements to make sure.. Continued!...
OOh sweet! where can i post that? is there a charge for the service?
Since the exterior is so horribly painted, i'm stripping it down and painting it another color, i wouldn't do this if it were the original pain, but now since the sin is done, there's no use on moderation, still undecided on the color the exterior will have, but i think i'll go for the "area 51" paint scheme the new broncos are coming out with. AND since i'm painting the exterior, i may as well do the interior too, the trim pieces are mostly intact and workable, but are heavily discolored from abuse and grime and they just look old and burnt.. so i'm still not sure if i'll put a wrap around them or actually paint them too, also planning on ditching the bench seat and adding buckets along with a center console, my dad who's a carpenter is already drawing up concepts for a custom one that'll match and look cool! i've got many more plans for the interior coming up, i'm staying all night uploading the backlog until i reach the progress of today, i'll explain some of my plans in those posts later tonight, hope you like em <3
