Aussiemj
Everything posted by Aussiemj
Hi everyone my 1990 4 litre 5 speed has a broken transmission lug mount . Can I use rear case from a yj or does have to be xj/Mj part thanks paul
2 inch lift is what i have got and will did install a drop brkt mainly for strength it just seams the sway bar is not wide enough with the jks disconnects.
hi guys this problem is on my xj not my mj but I thought i would throw it out there. my xj has two inch lift and the say bar disconnects hit the track bar holder and the sway seems to be 50mm to narrow. does anyone now the dimension of the overall width of a sway bar thanks
thanks
All my brake lines are rusted and the nut have seen better days. has any one used classic brake lines as they list Mj on there site. paul
Hi everyone What is this hole used for in the driver side front chassis rail. As you can seen the steering box has destroy the rail thanks paul
Thanks
That a indicator light to say you have unlock or lock your doors normally the indicators Paul
Hi everyone Does 91 + xj steering drag link and tie rod fit a 1990 mj https://www.ebay.com.au/itm/393005578416 This seem to be cost effective Paul
should i remove the pins
hi everyone just pull doors off the 1990 mj just one broken weld which i going to fix with t& m door frame strengthen. But the hinges are flog with wear in the pins. What to do ? thanks
I have not remove windscreen yet so trim pins are still there. If I use a 94 +rubber do I reuse the trim. Thanks
Hi everyone I want repaint the Mj. So I want pull out the front screen. My Mj has a trim around the windscreen. What windscreen rubber should I use thanks
My dash is bit tatty with broken mounts. Can any one suggest where can buy one. Please remember I am in Brisbane Australia Thanks
Hi guys The previous owner has change the front dif to a solid diff (remove select trac)but has left the piping to the transfer case. Can I remove this plumbing. What problem will I have. What else should I do. Thanks
Could you please add me thanks
Try dirtbound they make one
Hi guys as i am importing a Mj into Australia just wondering how many here. I know there was one other that was converted to the I think in Victoria.
To change do I need any new parts?
