BFeen
BFeen's Achievements
  1. Ok thanks. I guess I would just meter them as I turn the key on and off. I appreciate your help. They also have a wire, circled in red, that gets hooked into what I think is the dome light wire. Not sure but I would guess that is so the door switches light up. Thanks again.
  2. 90 Comanche and the manual regulator went up. But a conversion kit to make it power windows. The wiring diagram says to get the power from the + of the ignition switch. I am trying to get confirmation of which wire (color) is the positive and where to splice in. I appreciate any help.
  3. I'm new here and I have a '90 Eliminator and the vent windows have started to rust out at the bottom. Found a set off a '88 Cherokee for $60 but wanted replace the rubber weather stripping on them before installing. I can't seem to find anything online and didn't know if anyone knew where or even if we could get replacement seals for the vent windows. Thanks for any info you could provide.
