Sly_Jeeper
Everything posted by Sly_Jeeper
  1. Hope you find the manche! 88’ Renix Manual 2wd Sportruck
  2. Update nothing major 88’ Renix Manual 2wd Sportruck
  3. [emoji1360] 88’ Renix Manual 2wd Sportruck
  4. The Doors - Waiting for the sun 88’ Renix Manual 2wd Sportruck
  5. Thanks guys looks like I’ve got some thinking to do before i make things more complicated than they should be, I truly appreciate all the info. This community is awesome full of tips, tricks and stories from experience feels like a classroom i want to be in [emoji1320] 88’ Renix Manual 2wd Sportruck
  6. Thank you for the suggestions, i would not put anymore on the motor, these things run great as is, i was thinking good insulation for the firewall, back and doors, and raptor lining the floors in the case of a small water crossing and getting water on the floors. Electric heat would have to come from a rear mounted battery bank powering other accessories as well. For now these are just ideas, i understand that a good heater core replacement should do the trick. Thanks again for the info and advice. Lets keep these jeeps on the road and be creative [emoji41] 88’ Renix Manual 2wd Sportruck
  7. One thing led to another looking to replace a bad heater core i removed the dash heater box peeked under the carpet and it felt was soaked, i bypassed the leaking heater core last year but it looks like the carpet held in moisture. Also removed all the foam/vinyl up by the firewall and am now thinking of raptor lining the inside of the cab and finding another method for heating to avoid the dash removal in the future…i found out we’ve only got minor rust on the floor pans so at least thats a plus [emoji1360] wonder what that bagged material was for on the passenger floor? Sent from my iPhone using Tapatalk
  8. Rotella diesel 10w-30 n a seafoam Sent from my iPhone using Tapatalk
  9. Sly_Jeeper
    Dogs!
    Bruce 3 month old in the manche 1989 4.0 Renix Scratchy Ba/10 2wd Stock Short bed base
  10. Don’t force crank your windows, i tried using shin-etsu grease from the honda dealership $14 on the rails/sliders and i can now crank my windows up and down like butter if you can try it night and day difference 1989 4.0 Renix Scratchy Ba/10 2wd Stock Short bed base
  11. My tapatalk app doesn’t let me like reply’s so thank yiu for the help guys I'm in fresno,ca if i need a custom one ill go that route 1989 4.0 Renix Scratchy Ba/10 2wd Stock Short bed base
  12. Does anyone know if i can use the rear driveshaft from an xj I'm going from a 2wd pukegoat to ax15 w 231 or if i will beed a custom one my rear diff is a d35? 1989 4.0 Renix Scratchy Ba/10 2wd Stock Short bed base
  13. Dang 1989 4.0 Renix Scratchy Ba/10 2wd Stock Short bed base
  14. Have you fixed the O2 connection? 1989 4.0 Renix Scratchy Ba/10 2wd Stock Short bed base
  15. Tapatalk 1989 4.0 Renix Scratchy Ba/10 2wd Stock Short bed base
  16. Thanks, this answers my question exactly i just wanted to know if i could trust sitting on it and the latches or supports won't let go [emoji1360] Thanks for everyones input, my app doesn’t allow likes anymore 1989 4.0 Renix Scratchy Ba/10 2wd Stock Short bed base
  17. Anyone know the weight limit on the tailgate? [emoji1366] 1989 4.0 Renix Scratchy Ba/10 2wd Stock Short bed base
  18. Thank you, it turned out to be 0.13 1989 4.0 Renix Scratchy Ba/10 2wd Stock Short bed base
  19. I think ive got this in here right 1989 4.0 Renix Scratchy Ba/10 2wd Stock Short bed base
  20. The wires are 12 gauge, i am using a 15amp fuse now and has not blown. Do y’all think maybe i should use bigger wires? 1989 4.0 Renix Scratchy Ba/10 2wd Stock Short bed base
  21. I will be trying that today thank you. Hopefully this helps with little heat at idle 1989 4.0 Renix Scratchy Ba/10 2wd Stock Short bed base
  22. Thanks for the information and the tip [emoji1360] 1989 4.0 Renix Scratchy Ba/10 2wd Stock Short bed base
  23. What size fuse should i use inline? Simple ground to battery ground, positive coming from battery with fuse holder inline and a switch by the grill? It blew a 10 amp fuse thanks guys 1989 4.0 Renix Scratchy Ba/10 2wd Stock Short bed base
  24. Thanks a million [emoji1374] this will help me get it home and order the line 1989 4.0 Renix Scratchy Ba/10 2wd Stock Short bed base
  25. Went to pump gas on my lunch came back out to the truck and it had fluid on the floor [emoji53] took some pics and video, anyone had this issue before? I'm stuck but O’Reillys is 2 mins away It looks to be the line leaking 1989 4.0 Renix Scratchy Ba/10 2wd Stock Short bed base
