jason.cook.52206
Everything posted by jason.cook.52206
  1. Here are a few photos. Hope it helps. Sent from my SM-G935V using Tapatalk
  2. https://r.tapatalk.com/shareLink?url=https://comancheclub.com/topic/37100-rear-flat-fender-fitment-issues/&share_tid=37100&share_fid=53169&share_type=t Check the link. It appears the cherokee flares work but there is a slight gap Sent from my SM-G935V using Tapatalk
  3. I installed a brand new speedo cable. It bounces like crazy. I have heard to add lube into the cable. Does anybody know if it matters what type? Sent from my SM-G935V using Tapatalk
  4. The lift was already on mine when I got it so I don't know much about it but the front is a long arm with the rear soa. 31" tires. Rides super smooth but that is probably due to the long arm. Sent from my SM-G935V using Tapatalk
  5. Power stop brakes are great stuff also. I have them on our Jk, Tj and Xj. I love their stuff. I am interseted because I wouldnt mind doing the same setup on the comanche you are talking about. Looks to be a great option. Sent from my SM-G935V using Tapatalk
  6. Thank you for your help guys. After looking into it more I decided to give the pacesetter performance header a try. I will keep you updated on how it turns out. Sent from my SM-G935V using Tapatalk
  7. I have an 89 comanche 5 speed short bed 4.0 and my exhaust manifold is leaking. I can hear it as well as see where it has been welded to attempt fixes at the collector. I would like to replace it with a new stronger tube wall header but everything I am looking at is for xj's from 1991 and up. They say they will not work for my commanche. What options do I have? What have you guys used? Sent from my SM-G935V using Tapatalk
  8. I have the foot cable but I was able to find both online when I was searching for mine. I think it was A1 auto that I ended up ordering from. Sent from my SM-G935V using Tapatalk
