MjAllTheWay
Everything posted by MjAllTheWay
  1. Actually I don't think that is true. All it does is close off when the engine is cold so the engine can get to operating temp quicker. The heater core temperature control is separate. Most of the State XJs out here have it eliminated and they run just fine. You just run heater tubing from the radiator/engine straight to the heater core. They are different sizes. 5/8" and 1/2" if I remember correctly? 5/8" and 11/16". But you can use 5/8" on both. It's just a little tight on the 11/16" nipples. So what do i use jest a peace of metal tube and put a bend in it
  2. Can i jest do that?? What is the best way to go get the better one or jest put a pipe there??
  3. Jest a question mine is leaking and caused my jeep to over heat i have replaced it 2 times so i wan to know if this is a common problem and is there a better one i can get.
  4. Replaiced u joints on main drive shaft.
  5. can't find anything I'm replacing the rear u joints right now so i will look again
  6. Thats What i thought but why is it when i rotate the driver side the passenger side creaks i still can't figure that one out.
  7. Well the creaking is not from the tie rod ends and i do not beleve its comin from the ball joints had it up on the lift and if you spin eather of the tiers the passenger side creaks.
  8. I'm pretty sure my ball joints are gone and tie rods are toast and something in the front end is creaking so I'm thinking about getting a new D30 maybe a D44 how hard would it be to change. Do i have to modify anything in order to do this upgrade and will a non disco D30 get less MPG than a Disco or would it be better jest to put money in my D30 without replacing it.
  9. 1988,Comanche, Pioneer. 4.0 / Auto / D30 / D35 / Shortbed Build date: October 1987 Current Location:Reno Navada Status: Still on road Daily Driver Notes:Every skid plate,factory rear bumper,costum front with winch,with colum shifter. Roll bar from a dotsun pickup. Color: was blue but now is costum faded Gray primer. Interior is Gray no head liner and Has bucket seats had a bench from factory. 4 inch ish lift on 31s O and its rust FREE Current owner: Mark Harvey and its eather on the road or on the trail.
  10. fuel injected 5.0Ls you're looking for a yellow 19lb/hr injector Sweet Thank you.
  11. What year mustang will work and what engine
  12. You guys are lucky that people are selling Comanches i get 1 or 2 a year over hear
  13. No A/C no E-Fan :smart: I have no A/C and i have an electric fan so i don't now if thats true
  14. Man that sucks i don't really wana trim much.
  15. Pretty much what i did but i winched him out then pulled him out of a mud hole.
  16. Well i have 55w fog lights on my bumper that seemed very much brighter than them.
  17. Trying to find them a little confused i don't really use ebay much dose anyone know witch ones these are.
  18. I had those i didn't like them.
  19. Did you get them off ebay or somewhere else.
  20. I was thinking about something jest like that glad to hear they are as good as i thought they would be.
  21. So today i found a big hole in my head lights was pretty cool looking they still work, never did like them anyway so I'm going to replace them with something way better jest want to know if anyone has used the H4 conversion if so how are they and what is better than most things like that.
  22. Well I think I can get some 33s but I don't think I can fit them and have ok flex but I might jest see what it dose. Do u guys think I can get away with putting 33s under my MJ.
  23. This is what i did last weekend Thought i would share i pulled him for more than a couple miles up and down hills because he threw a rod.
  24. Ya i know i might jest turn them down and see what else i can score
