MjAllTheWay
Everything posted by MjAllTheWay
  1. Well i measured my truck and its 23and 1/2 inches in the front and 24 and 1/2 in the rear so I'm thinkin about a 4 inch lift.
  2. Sweet guys thans for all the help I'm going to measure my rig today and see how much lift it has and i don't really know if 33s will be in the future but i might jest go buy some maypops and see what it looks like and drives like.
  3. Well i have 3.55s should be good to spin the 33s i don't see any problems
  4. Dose anyone know how much lift it takes to fit 33s
  5. Sweet man i do have factory flares so i should be good.
  6. I'm confused on how you measure lift i pretty much made a lift but i don't really know how much i have i would like to know if i could fit 33s and what sway bar to go with so any answer are help full thanks.
  7. Replaced the alternator again 3ed time now within a year.
  8. Jest don't know if they would fit and be good off road.
  9. Thanks man i think it looks good jeswt want to put 33s on it and i would love M/Ts but no cash.
  10. Finally done lifting it i think well for now looks good Tell me what you guys think i should do next.
  11. Thanks man glad to hear it looks good to someone else but if you ever hit anything i bet one of us down in the states will be glad so send you whatever you need to fix it to save a Comanche would be way better than to have it in the JY so if you need a fender i will go pull one for you and send it to you. And thanks again i will have to add more pics of the leaf install i jest did lifted it about 2 more inches in the rear looks good if you ask me and i think i can fit 33s.
  12. don't have U bolts so can't finish but almost there.
  13. Jest got new leafs for the jeep of a 90 MJ that had a D44 couldent get the D44 but got the l i think you can tell witch is the old and witch is the new.
  14. O thank you soooooo much i will have picks up soon ish and thank you.
  15. Ok Guys i need help i now I'm a dumba$$ but i dident look to see if the big eye goes to the front of the leaf springs or if the little eye goes forward.
  16. Yep mine runs good runs strong jest has a low idle.
  17. I have the same problem but mine idles at like 400 to 500 mine is a 88 auto 4.0 trans but i can't find the problem.
  18. Washed it.This is the only time you will see the paint shine.
  19. Well if you unbolt your hole front end you can do it but i have the harbor freight spring compressor and i have used it a lot i don't think its the 10$ one but i would buy one if you are going to do it.
  20. The only way i know of doing it is with a spring comp.i don't think you can do it without
  21. I really like how that looks ware can i get some of those.
  22. found one more pic but it looks ugly
  23. Well i think i might jest weld a bar across my role bar and mount it thare.
  24. I go wheelin all the time so i don't want to have to get out of my truck and mess with it all the time.
  25. How did it stay up there.
