Everything posted by NC Tom
WOW! Mine is way too close!
Thanks Pete. Just checked to be 100% sure and my belt follows the same path as the diagram. Is it possible that my power steering is too high? I had that replaced a few years ago. Hard to believe it would move. Also, when I press down on the belt belt, how much deflection should there be? And should the AC compressor move when pressing belt?
I have non-working ac. The compressor is there.
CPS Plug inspection. Is this normal?
NC Tom replied to NC Tom's topic in MJ Tech: Modification and Repairs
That's tomorrow's plan! -
Resurrecting this ancient thread. Has anyone done this upgrade to remove the plastic clip connector but also keep the OEM metal fuel lines? I really hate those plastic clips and like to have them gone.
Well, I have spark. Fuel pressure whilst cranking starts at 39-49 then suddenly drops. At the same time this is happening, I noticed fuel dripping from the fuel pressure regulator/fuel line connection. This may be the problem. Thoughts? -
Just to verify. https://www.harborfreight.com/11-piece-noid-light-and-iac-tester-set-97959.html Thus will work for renix MJs? -
You're right. I'm going to HF today. I know the fuel pressure is low as it doesn't spray. However, a pressure gauge will be helpful. The injectors work. I had them all out, cleaned and tested them. Will test for spark tomorrow. You're only 3.5 hours away. Just swing by tomorrow! LOL! I admit it. My troubleshooting skills lack organization. -
Best I could. Not an easy task with a socket extension up there too. LOL! -
.25 + or - -
Check that. It's volts. -
Yes. Display reads 0.080 mv I think? -
New cps installed. Still no start. Notched the cps I'm getting .08 volts. That's worse than the old one. It's a Napa part. I'm pulling my hair out!!! -
Whew! I thought this was going to be a horrible experience, but it worked out. Hoping my NAPA part will work right off. -
My Dr. likes to say. "As we age . . .", before the bad news hits. Here's the image that cornfused.. I did even notice the CPS, just the bell housing and the hole. 2+2=7 in my head. Ugh! -
I know! I really thought I read on your site to drill out the bell housing with a pic if the bell housing. I'll have to check that again. I must be having a serious senior moment! -
I thought you drilled out the bell housing? -
The tape is ready for deployment. I don't see how you get a drill up in there, so probably not. I'm actually kinda backing off the whole mod thing. After reading about all the people breaking their new CPS! I can't afford to keep buying those things. -
That Black MJ is real purdy. Can I come over sometime and give her bath?
Funny. I figured if I suggested alligator clips or something like that, I would be told that I wouldn't get a good reading unless I soldered it. Can't win.
