88elimnator
Everything posted by 88elimnator
  1. Now all I'm runnin is the stock steering set up with a drop pitman arm, and a stock dana 30. With the wj knuckles, drag link, and tie bar I was looking to beef up the steering, and reduce drag link angle at the same time. The problem I'm finding out it that in order to use your exsisting hubs it has to be spaced to insure the correct alignment between the ball joints and the hub.And then the rotor has to be redrilled to match the 5.4 1/2 bolt pattern. But I've heard that you can use an Explorer sport trac rotor instead of redrilling. Just tryin to get as much info as possible before i spend more money than i need to. Also my reasoning for wanting junk yard parts is when something breaks its readily available at most any part store. you don't have to leave your rig on the trail for 2 weeks while a special order part arrives.
  2. cool thanks that looks easier.
  3. Hey guys, anyone know anything about using ford Explorer Sport trac rotors, when doing a WJ steering & brake upgrade? Do you still need to space the caliper and or hub?
  4. Nice truck, how did you make the gauge inlays?
  5. Anyone going to frostbites at Kansas Rocks next weekend?
  6. There not the bulb replacements, I kept breaking the stock tail lights so i wrapped the tail light hole with a small sheet of stainless and put in the oval trailer lights, cause they are cheaper and easier to find. So is there a relay I can get to fix this problem?
  7. ok so the turn signals worked fine then i installed led tail lights and now the turn signal is very very slow to blink when the lights are off, but don't work at all when lights are on. Does anyone know anything about this? Its driving me nuts, thank you
  8. 88 cherokee dana 30 98 cherokee 8.25 tj brake lines chevy alt. cherokee engine,trans cherokee engine wiring harness cherokee tcu (used to be a stick) np 231 out of a chevy blazer one honda bolt holding batt tray. lol lowering shakels for a full size chevy truck which provide lift on an mj
  9. Full size jeep truck 3in lift 33's nice paint new motor to haul my mj to the off road parks
  10. Its suppose to do that, unless theres a spool or the spider gears have been welded together.
  11. 28 thirty is getting closer
  12. What is a yard hopping day consist of?
  13. I live in Kansas city too. where abouts are you?
  14. Alright figured out the pics
  15. last weekend was the first time I had the comanche out at smorr off road park in seymour mo. It did great up intell I broke a u-joint in the front axle shaft. I would add pics if i knew how?
  16. You can also pull an alt. from an early 90s chevy truck or blazer with a 305 or 350. I found this out in a desperate attemt to get home one day.
  17. my motor holds at 2000 rpm Ive already changed the idle air control motor. does anyone have any ideas what could be causing it? Thank you
  18. just wondering, truck started stuttering just seeing if i could tell if it was bad before I bought a new one.
  19. Does any know can you bypass a crank sensor?
  20. does anyone know if the 23 spline np231 tcase has different input shaft lengths
  21. I might do that now that the auto might be done for.
  22. yea I pulled all the stuff out of a 90 cherokee and the transfer case wouldnt bolt up to the manual trans so I just switched it all
