88elimnator
Everything posted by 88elimnator
  1. I would but I got rid of that stuff awhile back.
  2. would starting the truck without tranny fluid burn up the tranny? Didnt shift it into gear or anything just run the motor I just put in to test it. it ran for about 30min. thanks
  3. no I didnt refill the converter I'll try leting it run in neutral for awhile. thanks
  4. yea theres fluid on the dip stick, and everything is hooked up. I just can't figure out what happend.
  5. I pulled it out with the motor drained all the old fluid put 5 quarts of new fluid in and it don't even try to go into gear
  6. yes its in there the way it came out and it worked when it came out
  7. Does anyone know how many quarts an AW4 trans takes I just put it back in after doing an engine swap and it won't do anything, I've already put 5 quarts in it. Thanks
  8. i can not get the springs to straighten up there bowen back at the top and forward on the bottom
  9. I already have adjustable lowers, and took the 2 1/2 spacers out in attempt to make the upper stock arms work but they don't seem to be long enough still.
  10. does an 88 comanche need new front upper control arms with a 4 1/2 IN lift running 33s? does anyone know. thanks
  11. installed new lower adjustable control arms and discovered I needed longer upper arms
  12. all that is possible except for knicking the crank I"ll have to check the other stuff. thanks.
  13. I was wondering if anyone knows how to fix the oil leak I've already changed the rear main seal and thats where it looks like its coming from and I notice alot of jeeps leak.
  14. 88elimnator
    hey guys
    Hey guys just signed up anyone in missouri.
