rangell
Everything posted by rangell
  1. rangell
    YES!!!
    Its not the owners fault.
  2. Thank you for this. This makes the hard work and all the learning I did on this worth it.
  3. Thank you. More pictures coming soon.
  4. I don't really know. I did my SOA and u-bolt eliminator in the back, then used some coil springs that were given to me in the front, along with Acos spacers to level.
  5. I bought some spray cans from an autobody paint supply. I can't remember the brand, but it was a two part, where you had to break a divider in the can to mix the paint and hardener. It was close to $50 a can....
  6. Here are some more in its current state, and some next to another local Comanche at a Jeep Meet and Greet.
  7. Here are some mocking things up to see how things were going to fit. IMG_0353.MOV IMG_0353.MOV
  8. Ok... Here are some pictures of when I brought it home, and began to tear it apart.
  9. I dried my floors out from all the rain we had last night. I really need to caulk the windshield wiper area....
  10. When I bought this MJ, that corner was wrinkled. So my idea is that I cut the bad sheet metal out, and installed another gas door, which is going to be an air and power outlet area. I belive it is an early JCR front bumper, and I add the win
  11. When I bought this MJ, that corner was wrinkled. So my idea is that I cut the bad sheet metal out, and installed another gas door, which is going to be an air and power outlet area.
  12. This is going to be for an air outlet and hopefully electrical outlet.
  13. So I am back. Things took a different route since I started this thread. the build specs are as follows. started as a 1990 2WD, 4.0, auto Comanche I did a full 1999 Cherokee conversion, front clip and dash. 5.3/4L60/231 drivetrain JK Dana 44 axles Clayton long arm frame stiffeners from front to back Spring over in the rear with a bastard leaf pack I think 4.5" coil springs in the front with Acos spacers to level it JCR front and rear bumpers with Warn winch in the front. Just painted HE4 base/clear. Still lots more to do.
