oregonman
Everything posted by oregonman
my 1988 jeep comanche "ole rusty"
oregonman replied to freakjeep93's topic in Member Projects: Your Comanches
Pete, I have provided him with links to a couple sties showing EVERYTHING we have been telling him. Both in this thread and in PM's. He doesn't read or doesn't understand what we continue to write for 15pages now... Its like my pop always said.. you can bring a horse to water.. but you can't make him drink. Here is another one. GUESS WHAT.. the VERY FIRST THING we see is a grinder.. wait for it... CLEANING THE STEEL!!! OMG, what is the guy thinking???? http://www.youtube.com/watch?v=jy75q-QSIjI Here is more then a couple dozen.. take you pick... http://www.youtube.com/results?search_q ... =0&spell=1 Like I said, I WANT TO HELP, WE ALL WANT TO HELP! But no one can help a person who will not listen. CW i know how to weld the right way now :banana: :banana: :banana: :banana: :banana: :banana: :banana: thanks for the link :cheers: -
:fs1: :fs1: damn kids . :USAflag: what did the deck look like and what was the #s ... put a ad in Craig list for a reward
thanks for pointing me in the right direction guys :cheers:
thanks for the great response guys . yeah i was thinking about it and when i got the truck it had those white rims with a blue and red line i think..... so i sanded those to make the glossy black...................... but yeah i think those are aftermarket...but
:clapping: very nice very nice Do you have steel break lines? and are you using those stock holders for the springs? or are you going to get limiting straps? but i like those bilsteins shocks how much did those run you'? :wavey:
Yes there is! And it is good! Sorry, just had to gloat! Keep up the good work! :clapping: Your doing a good job. and never let ANYONE STOP YOU NO MATTER WHERE YOU ARE IN LIFE. :chillin: and for the whole rust thing. i use sand paper . or if i get some money i buy a 20$ grinder @ the shucks.and you could also find a welder in craigslist for about 100$ or less .... but good job fixing up your truck .2wd would kicks @$$ for desert racing :thumbsup: later
tmans mj and xj projects...
oregonman replied to tmanhollister's topic in Member Projects: Your Comanches
depends on what i find first and price, plus i want discs in the rear. do you work at jwjeep or just a fan? my buddy troy works there. just a huge fan. :clapping: -
ight thanks guys i will buy another tsl. and have 2 MT spares . thanks for they advice.
sweet rims.nice truck. what rear end you going with ? ford 8.8 or Dana 44-60 . :waving: -
:clapping: :banana: :thumbsup: :thumbsup: :Canadaflag: :chillin: Dude nice job :waving:
k guys i have a question. i'm running 4 36.12.50.15s mickey Thomson baja belted but one is almost bald. so i seen a one 36" tire on Craiglist for $100 its a 36.12.50.15 super swamper tsl brand new with the little pokes still on it.but its about inch taller then the bald tire. the guy @ les schwab would not install the tire because it could cause my drive line to bind up?? but then he said if i wanted to bring just the tire in he would put in on the wheel for me so he would not be responsible for any damage that might happen ;...... so my question is if i run this tire that is a little bit taller the then other side on the rear axle , will complete destruction happen ? :huh???:
how would i make my stock rims bead locks?
that would be could to see were you put your tire @ .... but i guess you would not want to go through any deep mud :yes: :cheers: :USAflag:
:bowdown: :bowdown: :bowdown: :bowdown: :popcorn: :popcorn: :popcorn: :smart: :banana: man that is pimp. i can't wait to see the lift installed and some tires.
MY mj project(check it out) tell me what you think.
oregonman replied to oregonman's topic in Member Projects: Your Comanches
is that good? from what i understand, anything is better than a D35 - so yes. grrr my trucks is in the shop trying to get the running lights figured out i have no time to work on it right now. :headpop: :headpop: -
i did separate the fuse block from the firewall and cleaned everthing. and the is the running lights circuit a fuse or is a specail block thingy -
so install the new clutch master cylinder cleaned leads. and a new head light switch .still no running lights :fs1: -
amazing work man. i looked under my carpet and its pretty rusty i wish i had the time and tools to do what you do. but if you need some jeep parts check out this web site http://www.jwjeep.com/ they have a lot of jeep stuff for cheap i bought a slider window for $75 . they have a couple of Comanches................. you will love this truck when its done if you don't already :thumbsup: :wavey:
hope i'm doing this right lol
oregonman replied to AaronClarsen's topic in Member Projects: Your Comanches
nice truck man! blacked out is sweet. :clapping: :chillin: can't wait to see some more pics -
Smithe1811's Project Mjolnir
oregonman replied to smithe1811's topic in Member Projects: Your Comanches
:bowdown: that moon roof is pimp. :cheers: -
thank you . and is that a yes i do need to bleed the clutch master cylinder after install? -
James is right the cleaner will react with the brake fluid and it will be more difficult to get it clean. DISCONNECT the battery first before attempting to work around that fuse block. Remove the fuse block and then clean the mess caused by the leaking master. Then let it dry and repaint the area with a spray can before remounting the fuse block. Then re-connect the battery. yeah but it say it "drys clean" and yeah disconnect the battery.... but do i need to bleed my clutch after i install it? -
i have clue what axle shafts I'm running . I'm still trying to get my running lights working.... my clutch master leaked down on fuse box :fs1: so i got my new one to day Image Not Found and a can of break cleaner for the fuse box. if that does not work then i think it is the headlight pull knob switch.............. :wavey: -
Sway bars do nothing going straight down the road. They control body roll in turns. Just hope that you don't have to take any evasive maneuvers with that much lift. :shake: You already have the brackets. Just go to the junk yard and pick up a sway bar and get some disconnects. Willy i love my body roll. :banana: :banana: its fun :banana: :banana: My apologies. I'll do my best not to clutter your thread with any useful advice in the future. :shake: :fool: Willy willy your the man :bowdown: . for real .i don't know a whole lot. i just like going offroad and having a good daily driver . this truck has a long way to go before its trail ready. and the club knows everything about anything . and you are an expert. ............................... sorry if i seem like a a$$hole sometimes. I'm really a nice guy. just don't have much time or money to work on truck. times are rough . .. ... .... ....
