I bet I ended up with almost 7 in the rear and 5.5 in the front so I threw some 1 and 3 quarter spacers up front after almost killing myself with some autozone coil compressors hahah but I threw some 31's on them cause I had them laying around
He did say offset ball joints would correct it I just want to know if there's any other way! He said the axle tubes were straight, the readings were 1.3* on the passengers side wheel and 1.8* on the drivers side
Huh? Please explain how you determined the camber before the lift.
You can literally see the tires like this /---- that's what they look like so I know that it's camber and this wore down my tires in about 6 months from 100% tread to about 20% on one side.
/edit I'm half awake & mixed up toe with camber lol
What control arms did you use for your 6.5" lift?
I used control arm drops with stock arms and they were cambered out before I lifted it too so that couldn't the problem... Could it?
On my 86 Manche the front wheels are cambered negatively and it wears down my wheels on the inside very badly. It was like this before I did my 6.5 inch lift and its still there. I went to get it aligned today and they just couldn't do it they said! I would appreciate advice on fixing my camber! Thanks!
Title says it all, I want the full gauge cluster for my 86 Comanche with the 2.8l! With the tachometer, oil temp, water temp, voltage and gas in the left hand corner! Post pics of yours and name your price! :) thanks!
Just wondering if the NP 207 is a good or bad TC to me it seems pretty much the same as the 231 the vacuum switch I bought was for a NP231 and It fit right in my 207!
