01yellowxj
Everything posted by 01yellowxj
  1. persistent Two From the SE (GA/FL) and one shipped to me from AZ
  2. I have two 92’s and sold one a year ago (my 3rd 92 short bed
  3. Thank you
  4. O wow, and to think i wanted to remove it and put on a different decal. guess now i need to try and keep it
  5. My White 3/92 (4th mj ive owned) 1992 4.0 Automatic (column) short bed 4x4 Middle TN Bought from original owner has a side stripe ive never seen before on a MJ
  6. 03/ 1992 MJ - 1J7FJ26SrNL192909 4.0 171k 5 speed 4x4 d30/d35 shortbed cruise control Middle TN zero rust, waiting to build
  7. My Red MJ 2/92 (2nd MJ ive owned) Middle TN (bought from Utah) 4.0 Auto 4x4 short bed 108k miles d30 / d44 gray inside with bench AC
  8. Found a 92 Mj shortbed 4.0 auto in NV with 102k miles other than faded i havent found rust yet, alot of dust but no rust
  9. After several years i finally got another mj. from utah all its life so no rust found just lots of dust. 1992 auto colum shift 4x4 short bed. Exactly what i was looking for other than wanted white. has 102k miles and clean cardax. had it shipped to me in TN. other than missing paint (very faded on roof), clear coat peeling, and a few workable dents the body is solid. now to fix the oil leaks and rough idle now its in TN
  10. looking for a auto mj close to middle tn. really want a 91/92 but would entertain others. Going to be a father daughter build as she said she don't want my XJ. chad shfd2943@gmail.com
  11. Gonna try to make one if its soon. Drove the MJ today 12 miles and she rides better than my XJ!
  12. looking good can't wait to see it with the supercharger! Friend has a 4.0L TJ with a supercharger and wow. Makes me want to get a 4.0 and run it in my 66 AMC wagon (factory 232 straight 6) and bolt on a super charger. Too much wiring for me to figure out but it would keep the wagon a straight 6.
  13. Great thread and links! I have a XJ and bought a MJ (2.5L 5 speed 4.10 axles) a few months ago. I'm thinking about using my XJ C8.25 rear axle (4.10) and using it in the rear of the MJ so I will have a SPOA lift already since my XJ is getting a 8.8 rear axle. I can also use my new shocks off my XJ (Good for 4.5-6.5" lift) since I plan to upgrade them. I will have to see if the C8.25 axle uses the same E-brake set up and if so order the longer cable. Using the C8.25 axle do you see any other item that I may be over looking? I'm not sure what the importance is but on my D35 rear axle there is a ball looking thing bolted to my diff and another bracket near it but not connected. Then lift the front with coil springs, track bar, and longer UCA/LCA's and that should get me close to being done. Until I can get LCA brackets, a solid axle and delete the vac on the front D30.
  14. Looks like a good turn out. I have done nothing with mine other than title it in my name as my XJ is taking all my spare time. If I keep the MJ I hope to get to a meet soon. They are so similiar to the xj but still so different. Chad - Spring hill
  15. not sure how to post pics right now.
  16. Man, I need to do this to my 90Mj something bad. I hate the stupid... I mean dummy light dash. Mine is a 4cyl 5speed so guess I need to research the sensors and see what years fit.
  17. I just bought a 90 that has no dash lights as well. Will try the ground and see. My ebrake is all jacked up as well so maybe the PO knocked it off messing with the ebrake. Will mark this thread and post if I figure out mine.
  18. I have the same light on the classified/for sale forum, pair(2) lights $23.24 shipped. Don't have the Festoon LED bulb but they can be bought pretty cheap. Awesome. Will look more at my MJ I just picked up and see why mine don't work as well as my dash lights.
  19. $188 for a rear set of 3" springs from hellscreek....... humm makes me think a small 3" as I have 3" OME HD springs in the garage. Will have to research brake lines, shocks, etc.... Anyone running a 3" now? Would a 31" fit well? I also have a set of 4.5" front springs so maybe the 4" would actually be 4.5 over the worn factory leafs..... Is the metric tonne model easy to identify?
  20. On the xj rear axles there is also a white sticker on the axle tube that has the ratio if the tag on the pumkin is gone. I am a XJ person and just got a MJ so I'm learning. Not sure yet if I got a good one or not. No AC sucks if I want to make this my daily.
  21. 1. Roll Bar 2. Aftermarket rear bumper (off road style) 3. Aftermarket front bumper (off road style) Think I have a lwb (just got it so not 100% sure yet) Located in Middle TN Spring Hill, TN 37174 Thanks
  22. I like this rear bumper, just needs a 2" reciever. Was this custom built? Plan to do my tails also. Just wondering..... has anyone done it in reverse??? Instead of trim painted black leave it red and tint the lens?
  23. Word! Just ordered 2 sets and free shipping................. Day one of owning my MJ and I'm already improving it.
  24. What about putting AC in a 4 cyl MJ? My wrecked XJ out back has all the parts and is still a sealed system as I have not craked anything open but it was a 4.0 XJ, compressor mounted up by the battery/rad area. Not sure where the AC compressor goes on a 4 cyl motor.
