ggcnash
Everything posted by ggcnash
  1. Pull the rear disc setup off a liberty (03-07) I think those years are correct easy disc brake upgrade for the 8.25
  2. 8.25 is a great axle some say just as tough as the 44 don't change it.
  3. Trying to figure it out now
  4. http://www.jegs.com/InstallationInstructions/200/259/259-16789.pdf
  5. Derale 16789 unfortunately I do not have manual maybe I can track one down on the net http://m.summitracing.com/parts/der-16789
  6. Yep, just paralleled the temp sensor output wire to the fan controller. I will try this, seems to be easier than other options.
  7. I seen that did you just splice into the sensor? I upgraded to gauge from idiot light have new sensor just need to install
  8. Now asking all that, what is wrong with the threaded port in the block under exhaust manifold. Where the old temp sensors were, the port is still there in my 91 block with a plug in it has anyone used this location or know why I shouldn't?
  9. When your saying bottom hose you mean the return line to the radiator or to the engine? Driver side or passenger side sorry get confused? I would think it would be the return line (passenger) that would be hottest correct? rather then run through the radiator then get a reading? That's why I was thinking heater hose should be same water flow as return line?
  10. With my setup wouldn't this basically be the same as the return hose everyone suggests? It's just easier for me to purchase 3/4" fittings at local hardware store for the heater hose rather then the rad hose.
  11. My plan is set the temp at or around 205 for first with the second coming on around 215 and each shutting off with a 10* drop
  12. Sorry I have 97+ heater hoses in place eliminated the valve should have mentioned that, so I would be fine?
  13. Wouldn't the heater hose be the same water flow as the return hose? I have a 91 so I already have the port in the tstat housing but it's in use by the ecm sender.
  14. Hi guys picked up a dual fan derale controller for cheap I'm looking to install the temp sender in the heater hose just wondering some of the pros and cons of doing this thanks
  15. Also 8.25 easy to find
  16. What about 8.25 same width very underrated some would argue that it's as strong or stronger than 44
  17. [emoji106]
  18. Those are just headlight covers Google: "gts headlight covers jeep XJ" they have clear and smoked versions, buy them and tint darker[emoji106]
  19. I guess it is single speed? The knob has two position 2wd and 4wd lock
  20. Wife's: 2010 detonator 4.0 4x4
  21. ggcnash
    1J7FJ26L0KL483041
    [emoji106]
  22. Kk liberty, sorry I see u referred to KJ
