com_mako
Everything posted by com_mako
so it is time to replace the floor... and the rocker... and a part of the frame!! :nuts: :nuts: :nuts: :nuts: :nuts: check the pics :yes:
I also think that it is what I am going to do I do not understand why it is so complicated for some to send from US to Canada or Canada to US I am going to try tro get my money back still I do not have my injectors :mad: :mad: :wall: :wall:
Not true. We stock/sell the ACC kits for the MJ in both the carpet and rubber versions. They are MJ specific molded. EDIT: The kit you mentioned above is the ACC kit... how do your kits fit in the MJ ?? I see a lot of kit on ebay from different price I also need the carpet for my MJ but I don't really know which one to order :dunno:
still no answer from him.. :fs1:
yes I hope to have them... :fs1:
I order 2 sets of injectors on april the 24 but did not received them.. I know that I am far (Quebec Canada) but 3 weeks is a little long Does someone order from him during the last months ?? I email him via his Yahoo adress and on his web site, but no answer :( also call him, but no answer hope I did not make a mistake by ordering from him :wall: or maybe he is sick.. ?
does it fit well with the floor of the XJ ?? I am putting seat from a 1998 XJ with the floor bracket
did you use the interior carpet from the 1997+ XJ or the one from the MJ ?
I have tuff country 3.5'' of front lift in the back it is an AAL and it is SUA but I have a new MJ so this one will be for parts ( frame rust ) :ack:
:Canadaflag: there is no spyder in winter :Canadaflag: :yes: but thoses pics are ugly :ack:
:cheers: Thats the first thing that poped into my head when i looked at , i like it !!! It's in Canada, so not sure about that it would be strange a rebel flag in Quebec but it could be a cool jeep of hazzard :clapping:
look what I have found very rare in Quebec :clapping: http://www.lespac.com/vehicules/camions ... 27WWgrZZ12
Hidden Winch Design Proposal
com_mako replied to 87Warrior's topic in MJ Tech: Modification and Repairs
Just want to let you know that we all hate you (incredibly jealous) :cheers: I also have a cargo box light, 2 sets of brake light, a OEM bed liner... :brows: ;) -
I have a factory hidden winch :yes: check viewtopic.php?f=7&t=18149 -
no, they will not bolt at the same place and the bracket of the XJ 01 will not bolt to the floor unless you put the floor of a 97-01 XJ this is what I will do ! :D
what gauge steel is needed to patch the bed?
com_mako replied to MancheKid86's topic in MJ Tech: Modification and Repairs
I would say 16 gauge steel or try finding old doors and just cut part of what you need to replace the missing part on the bed ! -
buzzing noise ?? is the battery hot ??
since the 87-90 era has the renix system and later 91+ has OBD system, the TCU may adapt to the engine/trans load the renix system was more a basic electronic no brain system, so you choose power or normal shifting this is how I understand that switch
yes like that also it is like the tow mode on newer GM truck
winter tires would be a good idea !!!! the traction, breaking cornering are be far better than AT/MT tires I am from Quebec and it is the law !!
forget the a little bit... forgot to erase those word the transmission will shift at higher RPM
the transmission will shift a little bit at higher RPM it is like a towing mode on comfort, it will shift at normal RPM so better.. :nuts: fuel economy
no way !! the stock one broke in two when a try put pull my 2wd nissan pick up out of mud it is homemade, built from 3 steel tubes of 2x2 very easy to do !
my truck is sleeping outside with is brother the 1986... to cold to work on it and no the push bar is not factory... a home made replica of it :clapping: but the frame is still badly rust :ack: this is why I buy the other MJ, building one with two
