Everything posted by xj_dummy
Right side door handle in blue or just the backing plate. Mine shattered. :headpop:
1986 Comanche Custom Engine: 2.5 Transmission: 5 Speed Tranfercase: ? All I know its a 4X4 Axles: Stock, have no clue what they are. Wheelbase: Long bed Build Date: October 1985 Current Location, Reedley, California Status: Currently on the road and it is also my service truck for my business. Notes: When I bought it. It was just a stripped down Comanche with blue interior, Bench seat, no radio, idiot lite dash, push bar, step rear bumper, and no shell. Now it has bucket seats,Gage dash, stock radio with xm satellite, blue center console and commercial truck shell with L.E.D. clearance lites, 2X6 square tubing rear bumper with a 2inch reciever hitch, and tow hooks. Soon it will have A/C, and paint job. Current owner: Mike McCutchan :wavey:
Inspection FAILED! Noob needs help :)
xj_dummy replied to jbilly's topic in MJ Tech: Modification and Repairs
Change your plugs to factory, fuel filter, air filter, cap and rotor, gas cap. And also do an oil change. -
I will do that. thanks for the tip. What would the psi be?
Thank you for the info. Or the lack of it. :wall:
Where would I find my fuel pump?
I replaced the fuel filter on my 1986 2.5 Comanche, when it felt like its starving for fuel. But it still acts the same. Under idle and on the gas, it lopes? What would be the cause of it. Thanks.
1990 Cherokee, I bought one of those r-112 to r-134a kits at the zone. On top of the air compressor, there is two inlets one high side and one low. there is two valves? They look like valves to let the freon into the low side. Do you open up both to let freon in when installing r-134a?
My low speed on my 86 works some to not at all. High spped is ok. Is my motor going bad or :dunno:
My 1986 Comanche has passed the 100,000 mile mark today at noon. sniff sniff, I am so proud. :bowdown: I know I know that everyone else has that and then some. :bowdown: But I bought my MJ in Sept. 08 with only 86,000 miles. :rotf:
Socal1200r, I have a 1986 Mj with a bench seat and I converted it to Buckets. 1. Easiest way is to find a two door xj with buckets. (color might be a problem, I have tan buckets in my blue interior. Soon I will get them recovered) 2. Take out your bench seat, turn it over and using a drill, drill out the rivets on the bottom of the seat where your brackets mount. Do this also on the buckets as well. 3. Go to Fastenall or your local hardware store and but new bolts and lock nuts. 4. Reinstall your mj brackets on to your new buckets. 5. Install buckets. P.S. Are your in the navy? my nephew is in and at norfolk va.
I recently changed my pcv valve and new rubber gasket from the dealer, because my old one was spraying oil all over the valve cover. Any way, my idle went up to 1100 rpm from 700 rpm. Is this Normal? I really don't know because when I got the truck it had a loose rubber gasket and PCV valve. Can you Help me? :dunce:
Well my rear is saging because of the heavy shell on it so I would like to get it up higher.
http://fresno.craigslist.org/pts/1382197684.html I don't have a lift but will they help or hinder?
Ill be working for Keystone freight, delivering for Best Buy. Sorry I don't get a discount.
No I used the same one. I am going down to the local jeep dealer and ask the pros :doh: :fool: :shake: :rotf: , yea I know, I know.
Thanks. Any one else?
I know this is an Comanche Club, but I also own a 1990 Cherokee, 4.0, 4x4, with an automatic. I recently did a major rework of the brakes and radiator. For the radiator I replaced the closed system for a 92 and newer open system. A big improvement. And for the brake's, I removed all of the ABS master cylinder, pump and brain and installed a regular hydraulic master brake booster from a 1989. :dunno: Question? Are the ABS calipers and regular calipers the same? When I have bleed the brake system, the brake pedal doesn't seem that hard. :huh???: So what can I do?
There should be a lift section here in the forms?
xj_dummy replied to xj_dummy's topic in MJ Tech: Modification and Repairs
Thanks for the tip. :thumbsup: -
4.0 rallye package gauge cluster on a 2.5
xj_dummy replied to freakjeep93's topic in MJ Tech: Modification and Repairs
What is the year of the cluster? I installed a cluster out of a 1988 cherokee into my 86 mj. -
Forgive me that I am a little slow. But can someone in plain English tell me how to lift my 1986 jeep Comanche that has a 2.5 and a 5 speed LONG BED. I want it to be 2 to 3" higher. What parts do I have to change? Do I have to change the sway bar ends when I do a lift? At my disposal right now, I have; V 8 front coil springs from a Cherokee A 1989 jeep Cherokee parts truck Can I use what I have? Or should I buy New parts? thank you all for your help.
I like your swimsuit Model :thumbsup:
Here is mine. The plates are the factory bumper mounts. Image Not Found
I was curious about my 86 Comanche to see if it qualified for cash for clunkers. It didn't, its suppose to get 23 mpg.
I have heard from somewhere that I can use the rear springs or a portion of the springs from a cherokee to lift my 86 mj long bed. Also would installing the axel under the rear leafs be better or worse. I'm not trying to go nuts on a humungas lift, just enough so the rear dosent drag when 4 wheeling. I'm trying to keep it some what stock looking. All coments are welcome. Thanks
