I'm having an issue with my project MJ. Let's start with its history first.
It's a 99 Cheromanche. I've pulled everything from my old 99 XJ and stuck it in this MJ.
Image Not Found
In order to keep the fuel tank in the stock position, I swapped in the H.O. fuel rail, injectors, lines and pump.
The problem is whenever I try to start it; it takes about 5 times before it will fire up. Once it fires up, I have to work the gas pedal until the idle smoothes out or it will die. After about a minute of that, it will idle on its own and run fine. At this point I can kill it and start it back up with no problems. I just pulled and cleaned the throttle body and sensors on it, but it didn't seem to help. Any suggestions?
Thanks
Ben
