kdexter89
Everything posted by kdexter89
  1. I have been doing a lot of research on the AMC axle in the MJ and it's variants. The thing is I can't find if I should call it an M-20 or M-23. Could an axle guru give a guy a hand! Maybe provide some documentation on how to spot the difference in the two.
  2. Still looking to buy!
  3. How heavy do you think it is? Do you think 3-4 people could pick it up and load it? I have a deck over trailer ( deck is 3.5' off the ground ). Sorry for all the questions.
  4. The quality of your product surpassed my expectations. Some of the best fabrication work I have seen. Thank you.
  5. I forgot the most important question. Is it SWB or LWB?
  6. There is a VIN tag on the dash and there is one on the fire wall on the drivers side. They need to match the title. As for the stress cracks they are found around the steering gearbox mount, right behind the cab, and around the rear spring mounts.
  7. Are there any cracks in the frame in the usual stress areas? Also do you still have all the VIN tags for it? I am roughly 5 hours out so it makes it hard to check all these things out in person . Do you have any way to load this onto a trailer?
  8. I would like to know if you have thought about offering a complete kit not welded? If so I would like to purchase and do all the welding my self.
  9. I am looking to purchase a 97-01 Cherokee brake/clutch pedal assembly and aluminum bracket. Looking to spend $75-100 shipped to 63087. Depending on condition.
  10. i am in need of this info as well
