robfg67
Everything posted by robfg67
Can anyone help me to get the green ring around the Cigar Lighter to work? As you can see from the images below, there is a wire with a light socket receptacle in the Cigar Lighter assembly. The light socket receptacle is hot when the dash lights are on and my Cigar lighter is functioning. I removed the good 1181 bulb from the back of the clock assembly and inserted it into the light socket receptacle and it does not light-up. I also added an image of a similar styled bulb. It has a flat bottom with a metal contact on either side. What do I need to do to make this work? Image Not Found
I lent my truck to my son last Friday night because the weather fools predicted snow. While on the highway, my son "claims" the bed liner flew out the back. I called the local DPW yards to see if anything was picked-up and they had nothing. So here is my question. Do manufacturers still offer bed liners for the Comanche? Will a liner from a Ford Ranger or Chevy S-10 fit or are they custom to the Comanche. I have the short bed. Thanks
Ok, some needs to ask! Mattpioneer, is English your first language?
I just took a bunch of pics and this is the best one. There is definitely some rust deterioration on the on the flange at about 4 o’clock. The clamps look good and the inlet tubes are rusty but also look intact. I have about 3 gallons of gas in the tank now. If I remove the clamps (to wire brush the inlet tubes and the immediate general area) would fuel leak or pour out?
Here is the latest: I dropped a quilt down and grabbed a strong flashlight to inspect and found no obvious cracks, splits, holes or anything else that would cause fuel to leak. I was able to inspect all four sides of the tank all the way to the top and about 80% of the fuel delivery tubes. Unless you are a midget and/or a contortionist, it is physically impossible to visually inspect the top of the tank and the fuel tube connection and sending unit assembly/connection. Fortunately, there is no skid plate to deal with either, so dropping the tank should be fairly easy. I found a guy on eBay who sells the correct tank (for my Jeep) for $180 plus shipping, so I’ll go to him if necessary. Thanks to all for your help.
Guys, just to be clear, when you say to check the: "hard gas lines go into the fuel pump mounting flange apparently is a vulnerable spot. The lines vibrate or something, and develop a hairline crack where they go through the flange. That's where the leak is often found." Are you referring to the lines from fuel filler assembly on the right side of the image below or at the sending unit side on the left?
Marvel Mystery Oil Question!
robfg67 replied to robfg67's topic in MJ Tech: Modification and Repairs
I didn't want to overfill. The directions on the MMO bottle recommend that you substitute a quart of MMO for a quart of oil at next oil change. -
I drained about a quart of oil from the pan & addded about 20 ounces of MMO on Wednesday night (1/16/08). I'll update this post with any changes. -
I will definitely get the seal changed at some point-I just wanted to know if anyone had any experiences, good or bad with MMO. If it doesn't cause any harm and can possibly fix it, if only temporarily, that will be good enough for now. -
Yes I do. I'll assume that using a torque wrench on this project is important. -
I guess my next purchase will be a repair manual! -
Thanks Brent, I can handle oil pan removal-it was the transmission that had me worried. I understand that the MMO can swell some types of gaskets. I wasn't sure if it could do anything with a rubber seal. -
After degreasing the lower half of engine & transmission (to locate the source of the leak) I was able to identify the main rear seal as the source of an intermittent oil leak from my 1989 Comanche (with the I6 engine). I know the correct way of replacing the seal is to first remove the starter, transmission, and possibly oil pan to access the seal. I have never done this before and it is probably above my automotive skill level. Could I try Marvel Mystery Oil? Has anyone used this before? A mechanic friend of mine said it can be used to seal leaks, but he has seen it also seal the heater core in some vehicles. A half a bottle of Marvel Mystery Oil sounds like a reasonable attempt. What do you guys think? Here is a picture of my baby:
Idle Speed Stepper Motor Question-Problem Solved
I will look more closely at the vacum lines and try the battery disconnect exercise tomorrow. I agree that letting the idle speed screw out seems like more of a "work around". However, with that said, I drove to work this morning (about 7 miles) and she was purring like a kitten at idle-about 600 RPM. -
I adjusted the idle speed screw on the throttle body. You would think that the instructions in the FSM or on the new IAC might mention this step! -
No, the throttle cable is fine. -
So I installed a new Idle Air Control Valve from Advanced Auto Parts tonight and nothing changed. The engine still idles at 2,250 RPM’s. This is so frustrating-all I did was spray the inside of the throttle body (with TB spray cleaner) and clean the IAC. Can anyone suggest what to look at/fix/replace next? -
205K with 83K on rebuilt motor. I have dropped a ton of cash into her but like said earlier (in this thread), still significantly cheaper than buying new every 5 years or so-and a heck of a lot more fun!
Idle Speed Stepper Motor - Idle Air Control Valve - Idle Air Controller / I.A.C. I decided to clean the throttle body on my ’89 I-6 engine tonight. During this exercise, I removed the IAC and noticed there was some grime build-up on the pintle. The can of TB spray would not clean all the grime off, so I rubbed the pintle with a clean cloth (to remove the grime) and reinstalled. The Renix manual: http://www.pirate4x4.com/tech/billavist ... manual.pdf (on page 67) clearly states in the CAUTION paragraph, that if the pintle is removed too far from the motor it will break. Well, I must have done just that because now the engine is idling at 2,250 RPM’s. So here is my question, does anyone know of a way to fix this controller or will I be going to Auto Zone in the morning?
