Everything posted by blackdiamond
are you planning on doing radius arms with heims? if so don't. the upper arms have to have give in them. hence rubber bushings. if you put heims in the upper control arms it will rip stuff apart, or it won't flex at all. if you are set on using heims, and doing the radius arms, then only put one upper on. that will work fine. but with the 2 on there it will try twisting you axles, and it will find something it can break off. just letting you know. i know from personal experience. nice build though, i like where you are going with it.
Dual 44's and 37's (quick update)
blackdiamond replied to blackdiamond's topic in Member Projects: Your Comanches
well, i traded out the waggy front for a HP 44 out of a ford truck. i geared it with junk yard gears to 4:10's. i changed out the radius arms for a 3rd link, which is so much better feeling on and off road, and thats about it. here are the pictures. -
Tonight we got the rear end locked up, i can't wait till i take it ou and see what a difference it will make. i'm guessing there will be a little bit of a difference. i guess we'll find out. now it's time for some sleep as it is 12:00 am -
They are 12.50's on an 8x16 inch rim -
So i got a quick update to my project. i cut the rear lower quarter panels in preparation forr building my rear bumper, a little early, but they were all dented, and banged up anyway, so i figured it would make it look nicer. :rotf: i like the look. i can't wait till i have the bumper to protect it, and add some sweetness. here are some videos from a recent wheeling playing around trip. -
MJ#2 build w/leafs...NEW PICS
blackdiamond replied to jeepaholic's topic in Member Projects: Your Comanches
Ok, first, i think your truck is sweet! the 42's look good on it. it makes my 37's seem small. but it tought i would bring up something. the crossmember for the rear of the leaf spring mount might get in the way of your front drivshaft. i don't know if you were planning on dropping the shaft from on top of that crossmember or what, but it thought i would throw that out there. keep up the good work. :popcorn: -
correction, I wouldn't count rusty's out. thats what i ment to say.
sond like a good plan, although, i would consider a different tire if you want it to be on the road as much as it is off-road. the bogger will wear out pretty quickly and unevenly on the road. maybe a nice moterate mud terrian, or a different directional like the xterrains or baja claw or something. just a thought. about rusty's, i have a couple of their products, and they arent bad. i have heard that they have improved their stuff alot in the past couple years. i would count them out, but explore all your options.
here she is in the state she now sits. dual 44's 37's buddybuilt long arms, lots of fender hacking
ok, not that i'm saying its ok to wheel and drive, actually i think it is stupid to do so, only because i have a buddy who breaks something EVERY time he does it, but i have to agree with the one bad MJ dude. they could have been camping, or wheeling on somewhere where no one was around, if he broke his truck, or got stuck or something, thats only hurting him. and its kinda funny that you said if you had any power you would remove that picture, but instead with the power that you have, you decided to post it again. kinda funny.
actually, looking at your pictures, i think had you put the 3 inch lift springs in the front, your truck would look level front and rear, which is probably what the 3 inch lift springs front and rear are supposed to look like. i think it looks good without the shackles in the rear, and had you gotten the 4.5 inch lift rear it would look level with your 4.5 inch lift front. maybe its just me.
I finally got some new brake lines on my truck, and can now flex with confidence that i'm not going to snap one. here is a few pics, sorry, the pictures are really big. beware dial-up. Anyway, i was able to get the tire about 35 or 36 inches off the ground, i think thats a pretty good amount. -
yeah i'll admit the tires looked too big to me when the rims were white, but they look alot better with the rims black. the rims are 16 inchers. i got the tires, and bought the rims to match. the tires were only 50 bucks for all of them. -
took it out for a shake down run. i still some work to do to get it dialed in, but here is a shot of me playing around. -
here is with the rims painted black. tires look smaller now. time for bigger :brows: -
ok, for the last 6 months a have been putting together the stuff to swap in a waggy front 44 with wheel spacers, and J-truck rear 44 with the wheel spacers the stance is about 65 front and rear. i had to weld on the brackets off of a 2wd Comanche axle on to the front 44, that was kinda a pain, but it worked. i have to get some longer brake lines, and a have to get some manual locking hubs for the front axle, and a couple other things here and there. here are all the pictures. if you have questions about any of it, just ask me, I'll try to help the best i can. and here is my plan for a rear bumper, which will be my next project. and for comparison, here is my truck before
did you lose some of your turning radius? when i got it all bolted up i had lost a bunch of turning radius. so i ended up using a J truck pitman arm because it was longer, and i fixed my turning radius, in fact, i have never turned so tight.
yeah, its over the knuckles just how it was stock. I just was having trouble with the pitman arm and draglink. your truck looks sweet. how is the steering with the trackbar? any bump steer, or death wabble? thanks for your help.
I got a question for you, because i'm doing the same swap. when you did the waggy steering, how did you bolt the waggy tie rod end to the comanche Piman arm? the waggy is too big for the pitman arm, and i'm thinking i'll have to open up the hole with a tappered bit or something.
OK, officially the Flex thread, Post your flex shots!
blackdiamond replied to MiNi Beast's topic in The Pub
