jmaxj
Everything posted by jmaxj
  1. I had this same problem a month ago. If you search you'll find my thread with lots of info. But I ended up calling advance adapters and ordered the correct one.
  2. After a short conversation that was the correct one. Got it ordered and on its way. Thanks for the help.
  3. I didn't even think of AA. I'll be calling them. Thanks for the help guys
  4. Ok I finally solved the alignment tool problem. But now I'm having a pilot bushing problem. Anyone who's done this swap have the part number for the correct one. 3 of them I picked up for a CJ5 have a smaller diameter center hole. I'm about to just hone it out so I can get this jeep running
  5. Not yet, the first two I ordered were wrong. And the other two seem to be taking longer to come in. That's interesting. That's actually a good idea. Never thought of that.
  6. Well this isn't a new clutch kit, it's just the new clutch, pressure plate and flywheel that was on the motor :)
  7. I was assuming that's what you meant. But according to their computer it's only 5/8 so I dunno. 94
  8. Yes they do. They all list a 5/8 tip 10 spline. Just have 4 different diameters.
  9. I'll check that one out...thanks Now why would I want to buy a new clutch kit when the AX15 I got came with a new clutch, pressure plate and flywheel?
  10. I'm in the process of swapping the mj over to a AX 15 I've got the CJ-5 pilot bushing but what Clutch alignment tool do I need? The parts store lists 3 for an 87 Comanche.
  11. jmaxj
    Comanche bumper
    Possibly. 2 are for sure being used on a couple MJ projects but the one on the jeepspeed MJ project won't be used.
  12. jmaxj
    Comanche bumper
    I've got 3 haha
  13. Meat and badger. Green ZJ and 5.9 ZJ Too bad you guys didn't go up the cool way. But still fun going there anyway.
  14. I heard there was a sweet 1 ton MJ on that trip I needed to see. Guess I just did haha
  15. Like this Not a Chinook but same idea.
  16. There's a full size Comanche? I know of the J series and honcho, never heard of the Comanche FSJ
  17. dang holden your popping up everywhere these days.
  18. ford maverick and toyota 90-95 sr5
  19. mine was doing the same thing in my xj and mj so i pulled the pump yo replace them and found that the rubber pickup tube was off of the metal part, hose clamp was still on the tube so i just put it back on and they work fine the xj's has been like that for about 2 yrs now and the mj a couple months.
