87Chief Posted July 5, 2010 Share Posted July 5, 2010 Hey guys. I drove my mj the other day and when I got in I noticed the steering wheel moves... You can move it around like it's loose. But it also rides to the right... Any help will be appreciated! Thanks Link to comment Share on other sites More sharing options...
Eagle Posted July 5, 2010 Share Posted July 5, 2010 Does your truck have a tilt column? Link to comment Share on other sites More sharing options...
87Chief Posted July 5, 2010 Author Share Posted July 5, 2010 Yes it does Link to comment Share on other sites More sharing options...
jimoshel Posted July 5, 2010 Share Posted July 5, 2010 The wiggle (UJoint) that lets the column tilt is loose. You want to tighten the 4 bolts, if I remember right, that holds it together B4 any of the bearings fall out. Requires removing the steering wheel, locking plate and turn signal assembly. Link to comment Share on other sites More sharing options...
Eagle Posted July 5, 2010 Share Posted July 5, 2010 The procedure to tighten up a loose GM tilt column is all over the Internet. I don't have it bookmarked because I don't have one, but someone here posted a link to one of the writeups within the past few weeks (IIRC). Link to comment Share on other sites More sharing options...
87Chief Posted July 6, 2010 Author Share Posted July 6, 2010 Ok, thanks guys. I will try and do some research on that! Link to comment Share on other sites More sharing options...
mfpdm Posted July 6, 2010 Share Posted July 6, 2010 Ah the ole sloppy tilt column. I had to do this as well. Here's a link for you that has great pics and other links as well on the subject. http://brackmann.org/berkeley/Jeep/wren ... gwheel.htm :cheers: Link to comment Share on other sites More sharing options...
87Chief Posted July 6, 2010 Author Share Posted July 6, 2010 Thanks A lot! wow You wouldn't happen to know anything about AMSoil would you? Link to comment Share on other sites More sharing options...
mfpdm Posted July 6, 2010 Share Posted July 6, 2010 Bignuke said: You wouldn't happen to know anything about AMSoil would you? As a matter of fact, no. However, there is a member on here that is an AMSoil distributor or just a guru on it. Can't remember them right off hand but they have it in there sig. Link to comment Share on other sites More sharing options...
Eagle Posted July 6, 2010 Share Posted July 6, 2010 I think the resident Amsoil guru is whowey Link to comment Share on other sites More sharing options...
87Chief Posted July 6, 2010 Author Share Posted July 6, 2010 Ok thank you guys. Link to comment Share on other sites More sharing options...
Jeepman Posted July 6, 2010 Share Posted July 6, 2010 Here is another link that gives you a little more info... http://www.epiccomputer.com/dale/jeepjunk/tilt/tilt.html Link to comment Share on other sites More sharing options...
87Chief Posted July 6, 2010 Author Share Posted July 6, 2010 awesome, thanks a lot! Link to comment Share on other sites More sharing options...
xjrev10 Posted August 7, 2010 Share Posted August 7, 2010 Bignuke said: awesome, thanks a lot! Did you get it done? Link to comment Share on other sites More sharing options...
