Ever paint factory aluminum Wheels?
Guest vzehler
Do you have access to a compressor and spray equipment or are you planning on using a bomb can?
At an absolute minimum you need to scuff the wheel up to allow proper adhesion, but, if the clearcoat is chipping or eaten up with salt you should use aircraft stripper and remove all the coating (remove tire from wheel obviously. Prime them and paint them.
You can also refinish your wheel to factory by:
1. Break wheels and tires down.
2. Strip the factory finish off.
3. Sugar blast them.
4. Repolish the outside face of the wheel by starting with a 300 grit paper then moving up through 1200 grit to get the shine back.
5. Re-clear them.
I've done both... It's definitely something you should allow yourself plenty of time to do, especially if you want that factory finish i talked about... its a daunting task to do right.. but man does it look good when you finish...
We painted a factory set of rims on Rebecca's XJ that she ran temporarily until she went to 33's. We just sanded them for about 10 mins each and shot them with some paint. Turned out good and lasted quite well.
They look awesome. What type of paint did you use?
Guest vzehler
it really depends on how much corrosion you have on the wheels from salt.. you just want to make sure and get all of that off or your paint job won't last long.
if there in decent shape. just lightly sand them down and get wheel paint. paint them a color then they have clear coat for the wheels. i havnt used the clear coat yet but i should soon. i painted the ones on my truck and came out good.
I have painted a couple sets!! Pics in my build thread.
Last ones where the 10 spokes and the ones before that where the XJ Limited rims. Some people call them "lace" rims.
I used wheel/rim paint I got from the local Pep Boys store. I'm sure others have it. But the key with all paint jobs is PREP PREP PREP!!! I choice the have mine sand blasted. But not with sand as its quite abrasive for the alloy rims. Glass beads or other less abrasive media will work best. After that just follow the directions on the can. Multiple LIGHT coats give a great result followed by a couple coats of sealer/clear coat.
Here is what they started out like:
Image Not Found
Here they are aft sand blasting:
Image Not Found
Here is the paint:
Image Not Found
Here they are in the process of painting:
Image Not Found
Image Not Found
Image Not Found
Image Not Found
Image Not Found
They came out GREAT!!!
CW
i never had good luck with the duplicolor wheel coating. it dries even before it hits the wheel and is not smooth in my expiriances.
my tj i just primed and shot with a satin black ( the cheapest i could find) and its lasted great over 1 year now. jamminz.gif
It works fine for me... :D You'll can see how it came out.
CW
