maddzz1 Posted May 31, 2008 Share Posted May 31, 2008 I need to pull my axle shaft to replace the u-joint. Do I need to remove the diff cover and drain the diff before i pull the axle? Link to comment Share on other sites More sharing options...
LEAD_NOT_FOLLOW Posted May 31, 2008 Share Posted May 31, 2008 No Link to comment Share on other sites More sharing options...
jeepthing07 Posted May 31, 2008 Share Posted May 31, 2008 just jack that side up a little higher than usual and it won't pour out. it don't need to be jacked up crazy high or anything Link to comment Share on other sites More sharing options...
bryans87MJ Posted May 31, 2008 Share Posted May 31, 2008 Brake loose the hub nut (36mm) before you jack up the axle. Then stick it on a jack stand so it's a little higher than the other side and you are good ;) Link to comment Share on other sites More sharing options...
Pete M Posted May 31, 2008 Share Posted May 31, 2008 How old is the oil? Might be time to replace it anyways. Link to comment Share on other sites More sharing options...
maddzz1 Posted May 31, 2008 Author Share Posted May 31, 2008 How old is the oil? Might be time to replace it anyways. I'm not sure. Which i believe is another way of saying "time to change it." Can someone explain the friction modifier i need to add to the rear diff? Is there a gear oil that already has it added? Whats the best grease to buy to put in the bearing caps and grease the u-joints after install. I am also doing the rear driveshaft. Link to comment Share on other sites More sharing options...
