SuperWade2 Posted May 24, 2008 Posted May 24, 2008 ...at least I'm consistent in asking dumb questions.... Is there anything special about a Car Wash (Drive thru Gas Station Kind of thing) that would cause my Tranny/Tcase to get really warm, right afterward... as in feeling the heat thru the floor in the "hump" between the seats... I drove it home pretty much right afterward and parked it, but had to run back to work, so didn't crawl under to look at stuff, and took the TJ back to work. It's dark now, and cooled down I'm sure.... Washed 20 years of "dirt" insulation off maybe? Wade
Geonovast Posted May 24, 2008 Posted May 24, 2008 I suppose it's possible a lot of water got into your bellhousing, causing the clutch to slip a lot. You probably would have noticed it though..
SuperWade2 Posted May 24, 2008 Author Posted May 24, 2008 I suppose it's possible a lot of water got into your bellhousing, causing the clutch to slip a lot. You probably would have noticed it though.. Shifting and driving didn't feel any different... It was only 2 miles, with a top end of 35 mph thru town though...
jtdesigns Posted May 24, 2008 Posted May 24, 2008 did the car wash have the undercar brush?? could have pushed the cat up closer..
SuperWade2 Posted May 24, 2008 Author Posted May 24, 2008 did the car wash have the undercar brush?? could have pushed the cat up closer.. I don't think a brush, but maybe an undercoat spray...wasn't paying too much attention... I guess I just need to crawl under in the daytime and take a look to see if anything looks "weird"...
BLHTAZ Posted May 24, 2008 Posted May 24, 2008 Washed 20 years of "dirt" insulation off maybe? Wade That's what I was thinking. If it had one of the under side sprayers it probably cleaned off the "insulation" ;) .
dunl Posted May 24, 2008 Posted May 24, 2008 No one can really say unless you crawl under there and look, but please let us know what you find. Pictures always go good with beer, too. :)
