exjay33 Posted May 19, 2008 Share Posted May 19, 2008 Is there a certain year water temp-oil pres. sensor , for a 92 cluster that I am going to put in my 91 ? Is it better to buy new ones or just boneyard parts ? Link to comment Share on other sites More sharing options...
chicofuentes0224 Posted May 19, 2008 Share Posted May 19, 2008 Just get new ones at NAPA. They're not that expensive and you know they'll work right.....hopefully. Link to comment Share on other sites More sharing options...
Geonovast Posted May 19, 2008 Share Posted May 19, 2008 I'm using 4.0 88 sensors on a 4.0 92 cluster in a 2.5 91. Shouldn't be a problem with year. Link to comment Share on other sites More sharing options...
exjay33 Posted May 20, 2008 Author Share Posted May 20, 2008 So the idiot lights and gauges require different sensors correct? I keep reading conflicting posts that some use what is on the motor at the time of the change and some say they change. Will it hurt the gauge cluster to plug it in without changing the sensors? Link to comment Share on other sites More sharing options...
Silver88 Posted May 22, 2008 Share Posted May 22, 2008 I switched my 88 over a few months ago. The switches for the idiot lights won't hurt the guages, they just won't work. I had a problem finding the sending units at parts stores around here, but fortunately I was able to use the temp sender out of my 89 and found a usable oil press sender at the JY. Really though, you'd be best off with new. :cheers: Link to comment Share on other sites More sharing options...
SuperWade2 Posted May 22, 2008 Share Posted May 22, 2008 So the idiot lights and gauges require different sensors correct? I keep reading conflicting posts that some use what is on the motor at the time of the change and some say they change. Will it hurt the gauge cluster to plug it in without changing the sensors? Didn't hurt mine... I ran my new cluster for a few days before some sensors that I bought from a forum member arrived...Everything else worked oK... SW2 Link to comment Share on other sites More sharing options...
Geonovast Posted May 22, 2008 Share Posted May 22, 2008 No, they won't hurt anything...but they're not completely useless. When you're running, your oil pressure and temp gauges will be buried (can't remember if it's zero or max). If the 'light' comes on, the gauge will fly all the way to the other side. Link to comment Share on other sites More sharing options...
