FINALLY!
Been a long road, but 2x4 is now 4x4!
Checkin' out the dana 44 rear,SYE, and lockers in both 4.10 geared axles.
Image Not Found
Redone interior(found all black trim at JY). With a little addition to headliner and back panel that I call TED NUGENTIZED!
Image Not Found
Image Not Found
Now, I can finish this project!
Image Not Found
Image Not Found
(In response to a PM from ridergoatee)
Looks like your rear leafs are softer than your front coils. Even though your front tire is up all your flex is happening in the rear. That's why I thought you had the front sway-bar attached. That's how it would look, if you did. I don't think its a problem, more of an observation. Here is those pics I mentioned:
Here is a shot of my buddies sami:
See how the DS is stuffed up in the wheel well whale to hood is fairly level? If you look at yours, your hardly moving the PS tire and the hood is beginning to lean off level.
Here is my TJ. Same scenario:
Image Not Found
CW
CW
Actually, I bought the truck as almost as you see it. The cab and engine are black 92'. All other skins are 87'. So instead of painting cab to match, I painted vents and shadowed the stripes in white to match. Liked the way it came out. Sorta stands out amungst the rest. Have only had positive comments so far.
